null
Standard Buffing Compounds
Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes.
The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each.
The large bars are 1.25" x 1.25" x 6" and weigh approx. 1.5 lb. each.
We believe these industrial size bars represent a better value than the packaged tubes being marketed.
  • BELLY-PAD BUFFING APRON 18" X 11"
    BELLY-PAD BUFFING APRON The Belly-Pad Buffing apron is a covering designed to protect the polisher's body mid-section. It's made of heavy drill and twill cotton fabric, plied to 1/2" or more...
    $67.67
    Add to Cart
  • BLACK BUFFING COMPOUND JUMBO
    Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are...
    $15.80
    Add to Cart
  • BLACK BUFFING COMPOUND LARGE
    $10.74
    Add to Cart
  • BLUE BUFFING COMPOUND JUMBO BLUE BUFFING COMPOUND JUMBO
    $15.80
    Add to Cart
  • BLUE BUFFING COMPOUND LARGE
    $10.74
    Add to Cart
  • BROWN BUFFING COMPOUND JUMBO
    $15.80
    Add to Cart
  • BROWN BUFFING COMPOUND LARGE
    $10.74
    Add to Cart
  • GREASELESS COMPOUND - 120 GRIT
    GREASELESS COMPOUNDS - Greaseless Buffing compounds may be applied to almost any cloth buffing wheel, (sisal, spiral sewn cotton & loose cotton) turning it into a tough flexible grinding wheel. The...
    $17.70
    Add to Cart
  • GREASELESS COMPOUND - 180 GRIT
    $17.70
    Add to Cart
  • GREASELESS COMPOUND - 240 GRIT
    $17.70
    Add to Cart
  • GREASELESS COMPOUND - 400 GRIT
    $17.70
    Add to Cart
  • GREASELESS COMPOUND - 600 GRIT
    $17.70
    Add to Cart
  • GREASELESS COMPOUND - 80 GRIT
    $17.70
    Add to Cart
