GREASELESS COMPOUND - 600 GRIT
GREASELESS COMPOUNDS - Greaseless Buffing compounds may be applied to almost any cloth buffing wheel, (sisal, spiral sewn cotton & loose cotton) turning it into a tough flexible grinding wheel. The roughest casting edges can quickly removed. These materials do an excellent job of leveling highly contoured surfaces quickly.
Store at room temperature or below.
We recommend shipping these products by air during summer months to ensure the product does not melt during shipping.
For best performance, and to make your greasless compound last longer on the buff, treat the wheel with Glu-Tite before applying the compound.
4 Reviews Hide Reviews Show Reviews
Great stuff
Does what its supposed to do!
Polishing Knife Blades?
If you want the satin finish you just can't get with the standard Black Buffing Compounds, this is the product you need to use! Messy to apply? You bet! But it comes off easily enough. As for storage, if your "Shop" stays relatively cool, just put in a Ziplock style plastic bag(or 2) and it'll be fine. Warmer area? In the baggies and just stick it in your fridge, or it can melt.
Great product. Works well.
Better than hand-sanding
This greaseless compound is a life-saver! It is messy to apply, needs maintanence to keep it from drying out or melting, but it is worth the trouble because it works fast. The 600 grit cuts fast and leaves a nice satin finish. If you are hand-sanding scratches out of metal, do yourself a favor and get a spiral wheel and some of this greaseless compound.
