GREASELESS COMPOUND - 400 GRIT
GREASELESS COMPOUNDS - Greaseless Buffing compounds may be applied to almost any cloth buffing wheel, (sisal, spiral sewn cotton & loose cotton) turning it into a tough flexible grinding wheel. The roughest casting edges can quickly removed. These materials do an excellent job of leveling highly contoured surfaces quickly.
Store at room temperature or below.
We recommend shipping these products by air during summer months to ensure the product does not melt during shipping.
For best performance, and to make your greasless compound last longer on the buff, treat the wheel with Glu-Tite before applying the compound.
Great stuff
Does what its supposed to do!
Nice Finish
I find the 400 grit lasts longer on the buff before having to load up again. I imagine the finer grit and using light pressure leads to this. The best way to apply on wheel is use the Caswell adapter on drill and slow spin the compound on, has worked for me.
