GREASELESS COMPOUNDS - Greaseless Buffing compounds may be applied to almost any cloth buffing wheel, (sisal, spiral sewn cotton & loose cotton) turning it into a tough flexible grinding wheel. The roughest casting edges can quickly removed. These materials do an excellent job of leveling highly contoured surfaces quickly.
Store at room temperature or below.
We recommend shipping these products by air during summer months to ensure the product does not melt during shipping.
For best performance, and to make your greasless compound last longer on the buff, treat the wheel with Glu-Tite before applying the compound.
4 Reviews Hide Reviews Show Reviews
Great stuff
Does what its supposed to do!
Nice flow - great results
Flows on to the cotton wheel and leaves a nice finish ready for a final buff.
Awesome
Great product for removing scratches and carding/brushed finish off of metal. I am using this compound as a starting point and working to 400 grit on stainless steel. You have to find the right rpm and amount of pressure to keep excess material from flying off wheel when applying.
Excellent product
I've used the entire family of greaseless compounds for my motorcycle polishing projects and the 180 grit is perfect for starting off where the aluminum is not sandcast. It isn't messy when the right measures are used to prevent sling. (I use a cardboard box with the flaps up on one side) I highly recommend this product!
