Quick view NotCHead sku: NTCHCA 1/2" COLLET FOR NOTCHEAD GRIP MSRP: Now: $50.54 Add to Cart Compare Quick view Caswell sku: AA275 ARBOR ADAPTER MSRP: Now: $6.95 Add to Cart Compare Quick view Caswell sku: MAND22 BENCH MANDREL - 1/2 MSRP: Now: $76.52 Add to Cart Compare Quick view Caswell sku: MAND21 BENCH MANDREL - 5/8 SHAFT MSRP: Now: $118.16 Add to Cart Compare Quick view Caswell sku: CAL995 CHUCK ADAPTER 0 - 1/2 C-4 MSRP: Now: $40.47 Add to Cart Compare Quick view Caswell sku: CA995 CHUCK ADAPTER 0 - 1/4 C-2 MSRP: Now: $22.83 Add to Cart Compare Quick view Caswell sku: SAXLRT1 EXTRA LONG SHAFT EXTENDER 1/2 RH MSRP: Now: $33.12 Add to Cart Compare Quick view Caswell sku: SAXLLT1 EXTRA LONG SHAFT EXTENDER 1/2" LH MSRP: Now: $33.12 Add to Cart Compare Quick view Caswell sku: SAXLLT5 EXTRA LONG SHAFT EXTENDER LH 5/8" MSRP: Now: $33.12 Add to Cart Compare Quick view Caswell sku: SAXLRT5 EXTRA LONG SHAFT EXTENDER RH 5/8" MSRP: Now: $33.12 Add to Cart Compare Quick view Caswell sku: FA39 FLAPPER ADAPTER - STANDARD - STAINLESS MSRP: Now: $68.93 Add to Cart Compare Quick view Caswell sku: FA07XL Flapper Adapter 5/8 UNC Thread with 1/4" Collet - Extra Long MSRP: Now: $81.58 Add to Cart Compare Quick view Caswell sku: FAM12175 Flapper Adapter Metric M12 x 1.75 MSRP: Now: $68.93 Add to Cart Compare Quick view Caswell sku: FAM142 Flapper Adapter Metric M14 x 2.0 MSRP: Now: $68.93 Add to Cart Compare Quick view NotCHead sku: NCH-PG NOTCHEAD POLISHING GRIP MSRP: Now: $126.44 Add to Cart Compare Quick view 1/2" COLLET FOR NOTCHEAD GRIP For use with the NotcHead Polishing Grip, this larger collet makes a valuable tool even more versatile. The soft aluminum jaws quickly grip the threads of the bolt so the head can be polished 360 without damage. It secures the bolt evenly with a... MSRP: Now: $50.54 Add to Cart Compare Quick view ARBOR ADAPTER These sturdy adapters are great for mounting, wire wheel brushes, grinding wheels, cut off wheels, buffs etc onto any chuck power tool. 1/4" shaft fits into chuck 1/2" threaded end. Order buffing wheels with 1/2" hole. MSRP: Now: $6.95 Add to Cart Compare Quick view BENCH MANDREL - 1/2 Attach these mandrels to an electric motor with a V Belt to make a HIGH QUALITY, low cost work station for various sanding, polishing and buffing operations. Will run wheels up to 1" thick. Features high quality precision grade die cast ball bearing... MSRP: Now: $76.52 Add to Cart Compare Quick view BENCH MANDREL - 5/8 SHAFT Attach these mandrels to an electric motor with a V Belt to make a HIGH QUALITY, low cost work station for various sanding, polishing and buffing operations. Will run wheels up to 1" thick. Features high quality precision grade die cast ball bearing... MSRP: Now: $118.16 Add to Cart Compare Quick view CHUCK ADAPTER 0 - 1/2 C-4 This handy accessory turns an ordinary motor into a bench mounted drill. Just attach this adapter any 1/2" right threaded shaft or one of our shaft extenders. The Chuck Adapter is seen here fitted to a shaft extender. MSRP: Now: $40.47 Add to Cart Compare Quick view CHUCK ADAPTER 0 - 1/4 C-2 This handy accessory turns an ordinary motor into a bench mounted drill. Just attach this adapter any 1/2" right threaded shaft or one of our shaft extenders. The Chuck Adapter is seen here fitted to a shaft extender. MSRP: Now: $22.83 Add to Cart Compare Quick view EXTRA LONG SHAFT EXTENDER 1/2 RH Designed especially for larger buffing & polishing units. The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces. Slides onto 1/2" diameter shaft and tightens with two grub screws. Great for... MSRP: Now: $33.12 Add to Cart Compare Quick view EXTRA LONG SHAFT EXTENDER 1/2" LH Designed especially for larger buffing & polishing units. The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces. Slides onto 1/2" diameter shaft and tightens with two grub screws. Great for... MSRP: Now: $33.12 Add to Cart Compare Quick view EXTRA LONG SHAFT EXTENDER LH 5/8" Designed especially for larger buffing & polishing units. The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces. Slides onto 5/8" diameter shaft and tightens with two grub screws. Great for... MSRP: Now: $33.12 Add to Cart Compare Quick view EXTRA LONG SHAFT EXTENDER RH 5/8" Designed especially for larger buffing & polishing units. The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces. Slides onto 5/8" diameter shaft and tightens with two grub screws. Great for... MSRP: Now: $33.12 Add to Cart Compare Quick view FLAPPER ADAPTER - STANDARD - STAINLESS The Flapper Adapter mounts onto any angle grinder with a 5/8 - 11 shaft (almost all grinders), and allows you to mount any wheel with a 1/4" shaft onto your angle grinder. Mount flap wheels, cutoff wheels, buffing wheels, grinding wheels, carbide burrs... MSRP: Now: $68.93 Add to Cart Compare Quick view Flapper Adapter 5/8 UNC Thread with 1/4" Collet - Extra Long The Flapper Adapter mounts onto any angle grinder with a 5/8 - 11 shaft (almost all grinders), and allows you to mount any wheel with a 1/4" shaft onto your angle grinder. Mount flap wheels, cutoff wheels, buffing wheels, grinding wheels, carbide burrs... MSRP: Now: $81.58 Add to Cart Compare Quick view Flapper Adapter Metric M12 x 1.75 The Flapper Adapter mounts onto any angle grinder with a metric M12 x 1.75 shaft, and allows you to mount any wheel with a 1/4" shaft onto your angle grinder. Mount flap wheels, cutoff wheels, buffing wheels, grinding wheels, carbide burrs etc. Made in... MSRP: Now: $68.93 Add to Cart Compare Quick view Flapper Adapter Metric M14 x 2.0 The Flapper Adapter mounts onto any angle grinder with a metric M14 x 2.0 shaft, and allows you to mount any wheel with a 1/4" shaft onto your angle grinder. Mount flap wheels, cutoff wheels, buffing wheels, grinding wheels, carbide burrs etc. Made in... MSRP: Now: $68.93 Add to Cart Compare Quick view NOTCHEAD POLISHING GRIP Tired of your bolts shooting across your shop? Tired of your bolts getting too hot to hang on to while polishing? This award-winning Polishing Grip provides a solid, secure grip for polishing or grinding. The NotcHead™ Polishing Grip will grip almost... MSRP: Now: $126.44 Add to Cart Compare 1 2 Next 1 2 Next Compare Selected × OK
