null
Epoxy Repair Materials
  • AQUAMEND EPOXY AQUAMEND EPOXY
    AQUAMEND EPOXY
    "No Boat Should be Without it" After proper mixing, AQUAMEND® molds like clay and may be used to patch dings, scratches, cuts, gouges, and holes in fiberglass, metal, and wooden boat decks and...
    $9.48
    Out of stock
  • FASTSTEEL EPOXY FASTSTEEL EPOXY
    FASTSTEEL EPOXY
    "Don't weld it, FASTSTEEL it!" FASTSTEEL® is a hard kneadable, steel-reinforced, epoxy putty adhesive sealant that mixes in just one minute to provide fast repairs to items made of ferrous and...
    $9.48
    Out of stock
  • INSTACRETE EPOXY
    INSTACRETE EPOXY
    "Concrete in a Tube"   Ideal for Anchoring, Patching and Sealing Concrete, Mortar and MasonryINSTACRETE® is an amazing polymer compound for instant concrete repair. Easy-to-use INSTACRETE® shapes...
    $9.48
    Out of stock
  • Lantern Fount Sealing Kit Lantern Fount Sealing Kit
    Seal Pinholes and Small Leaks In Lantern Founts & Fuel Tanks Contains Enough Sealer For One 1 Quart Fount Permanently Seal Lantern Founts With Our Two Part Phenol Novolac Epoxy Phenol Novolac Epoxies...
    $37.94
    Add to Cart
  • QUIK TITANIUM - 4 OZ
    QuikTitanium Epoxy Putty Stick is a hand-kneadable, titanium-reinforced, epoxy putty adhesive sealant for high-temperature applications. It is designed to bond and repair materials that will be...
    $9.48
    Out of stock
  • QUIKALUMINUM EPOXY
    QUIKALUMINUM EPOXY
    "Fix it Fast and Make it Last" QUIKALUMINUM® is a hand kneadable, non-rusting, aluminum reinforced, epoxy putty that mixes in just one minute to repair aluminum easily and efficiently. It comes in a...
    $9.48
    Out of stock
  • QUIKCOPPER EPOXY QUIKCOPPER EPOXY
    QUIKCOPPER EPOXY
    "The Plumber in a Tube" QUIKCOPPER® is a hand kneadable, copper reinforced, epoxy putty that mixes in just one minute to provide fast repairs to pipes, tanks, and vessels made of copper, brass,...
    $9.48
    Out of stock
  • QUIKPLASTIK EPOXY
    QUIKPLASTIK EPOXY
     "The Flexible Solution for Plastic Repair" QUIKPLASTIK® is a hand kneadable, fast setting epoxy putty that bonds to all major plastic types except polyolefins. When mixed, QUIKPLASTIC® is the...
    $9.48
    Add to Cart
  • QUIKWOOD EPOXY QUIKWOOD EPOXY
    QUIKWOOD EPOXY
    "The Woodworker's Dream" Repair, Rebuild, Restore Anything Made of Wood QUIKWOOD® is a remarkable polymer compound for instant wood repair. Easy-to-use QUIKWOOD® molds like clay, then dries like wood...
    $9.48
    Out of stock
  • QUIKWOOD EPOXY MAHOGANY QUIKWOOD EPOXY MAHOGANY
    $6.95
    Out of stock
  • QUIKWOOD EPOXY PINE QUIKWOOD EPOXY PINE
    QUIKWOOD EPOXY PINE
    $6.95
    Out of stock
  • REPAIRITQUIK EPOXY PUTTY - 4OZ
    Repair loose or cracked wall, floor tiles Electrical use in place of tape or plastic connector Fabricate small parts, mend holes Attach fixtures, machines, tags and signs Use for 1001 Household and...
    $9.48
    Out of stock
