GREASELESS COMPOUNDS - Greaseless Buffing compounds may be applied to almost any cloth buffing wheel, (sisal, spiral sewn cotton & loose cotton) turning it into a tough flexible grinding wheel. The roughest casting edges can quickly removed. These materials do an excellent job of leveling highly contoured surfaces quickly.
Store at room temperature or below.
We recommend shipping these products by air during summer months to ensure the product does not melt during shipping.
For best performance, and to make your greasless compound last longer on the buff, treat the wheel with Glu-Tite before applying the compound.
3 Reviews Hide Reviews Show Reviews
Smells great.
Haven't used it yet but got it free with points, as it's from Caswells I know it will work just fine. has a great mint smell.
Great stuff
Does what its supposed to do!
Great Product
Have been using these Formax greaseless compounds and find them to be useful and faster than sanding by hand. Some tight areas can be done with the edge of the buff with light pressure.
