null
Antiquing Solutions
Use these products to antique or change the color of most metals, without power or heat in most cases. Just dip.
To get help choosing a solution, visit our Metal Finishing Solutions Page.
  • ALUMINUM BLACKENER A385
    Aluminum Blackener A385 Ideal For Touching Up Black Anodized Parts Vary the color from a rich pewter gray to a deep black by changing dilution and immersion times. Completely colorfast through age or...
    $31.61
    Add to Cart
  • BLACK & BROWN OXIDIZER BLACK & BROWN OXIDIZER
    Black & Brown Oxidizer Blackens silver and nickel and browns copper and brass. Mix 15% concentrate with 85% water. Use as a dip at room temperature.
    $31.61
    Add to Cart
  • CASWELL SEALER - 4 FL OZ
    Caswell Sealer Concentrate Caswell Sealer is a fast drying coating that penetrates porous materials such as cloth, leather, plaster of paris, concrete etc. rendering it non-porous. The...
    $13.90
    Add to Cart
  • CASWELL SEALER CONCENTRATE - QT
    $76.52
    Add to Cart
  • Chocolate Brown 16 fl oz Chocolate Brown 16 fl oz
    Chocolate Brown Produces a chocolate brown to antique brown finish on copper and brass. Mix 15% concentrate with 85% water. Use as a dip at room temperature.
    $31.61
    Add to Cart
  • Cyclone Parts Dryer
    Cyclone Parts Dryer
    Blackening Parts? Need Fast Part Drying? The Cyclone Parts Dryer speeds up the drying process, helps prevent flash rusting and dries without water spots Features 11€ x 10€ x 13€ One inch tray depth...
    $125.24
    Add to Cart
  • Flemish Grey & Blackener 16 fl oz
    Flemish Grey & Blackener For use on copper, brass and bronze. 15% to 20% by volume solutions produce black to blackish-brown US 10B (Oil Rubbed) finishes on copper and brass with immersions of 1 to 3...
    $31.61
    Add to Cart
  • GUN METAL BLUE
    GUN METAL BLUE
    Gun Metal Blue (not for steel) Produces gun metal blue, black, brown and slight purple on copper, brass, bronze, white metals, silver and tin lead alloys. Used at 10-50% by volume at 65-85° F. Does...
    $31.61
    Add to Cart
  • SWAB ON COPPER BLACKENER
    Swab On Copper Blackener An instant acting swab-on/touch-up chemical conversion finish for copper and its alloys. Color can be varied from light brown to brown-to-black.
    $31.61
    Add to Cart
  • Tiffany Green 16 fl oz Tiffany Green 16 fl oz
    Tiffany Green The original solution for the €˜greening' of the copper components of Tiffany lamps. Apply the solution, undiluted, with a soft paintbrush. Allow to react on the copper overnight. ...
    $31.61
    Add to Cart
  • ZINC BLACKENER - 1 PINT
    Zinc Blackener A360 A room temperature blackening process for die cast and plated zinc surfaces. The very mild acidic liquid concentrate is diluted with 9 parts of water for a 10% by volume working...
    $31.61
    Add to Cart
