null
Powder Coating
  • BLACK OXIDE CONCENTRATE 1 QT
    Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 quart...
    $70.14
    Add to Cart
  • HANDHELD IR THERMOMETER
    Probably the most useful tool in any powder coater's toolbox - accurate temperature readings are essential to good coatings. Curing cycles are determined by part temperature, not oven temperature,...
    $97.39
    Add to Cart
  • High Temp PC Tape - 1" High Temp PC Tape - 1"
    High Temperature Masking Tape Polyimide tape is perfect for high temperature masking needs. Withstands temps up to 600F. Copper colored Maximum Temperature: 500F Total Thickness: 2 mils Excellent...
    $44.90
    Add to Cart
  • High Temp PC Tape - 1/2" High Temp PC Tape - 1/2"
    $27.82
    Add to Cart
  • High Temp PC Tape - 2" High Temp PC Tape - 2"
    $89.17
    Add to Cart
  • IRON PHOSPHATE PRIMER - 1 GALLON
    Increase the corrosion resistance of your powder coated parts. Caswell Iron Phosphate Primer is a concentrated liquid, multiple temperature, detergent iron phosphate. It provides metal surfaces with...
    $80.95
    Add to Cart
  • IRON PHOSPHATE PRIMER - 1 PINT
    $31.61
    Add to Cart
  • POWDER COATING MASKING TAPE - 1 POWDER COATING MASKING TAPE - 1
    POWDER COATING TAPE - 2 MIL This 2 mil polyester tape has a 1.3 mil coating of a specially cured silicone adhesive that removes cleanly when exposed to temperatures that do not exceed 400 degrees F...
    $10.74
    Add to Cart
  • POWDER COATING MASKING TAPE - 1/2 POWDER COATING MASKING TAPE - 1/2
    $6.31
    Add to Cart
  • POWDER COATING MASKING TAPE - 2 POWDER COATING MASKING TAPE - 2
    $34.78
    Add to Cart
  • SILICONE CAP KIT SILICONE CAP KIT
    SILICONE CAP KIT
    For Powder Coating, Plating, Anodizing or Painting Prevent powder coating, plating or anodizing from getting into sensitive areas. Withstands 600 deg F
    $129.00
    Add to Cart
  • SILICONE FLANGE KIT SILICONE FLANGE KIT
    SILICONE FLANGE KIT
    $129.00
    Add to Cart
  • SILICONE PLUG KIT SILICONE PLUG KIT
    SILICONE PLUG KIT
    $129.00
    Add to Cart
