Quick view Caswell sku: F515-422 80 GRIT LIQUID ABRASIVE SANDPAPER MSRP: Now: $75.31 Add to Cart Compare Quick view Formax sku: F515-6147 ALL PURPOSE STAINLESS COMPOUND MSRP: Now: $21.49 Add to Cart Compare Quick view Formax sku: F515-6126 ALUMINUM CUT & COLORING COMPOUND MSRP: Now: $18.96 Add to Cart Compare Quick view Formax sku: F515-6127 ALUMINUM HIGH LUSTRE COMPOUND MSRP: Now: $18.96 Add to Cart Compare Quick view Formax sku: F515-576 BELLY-PAD BUFFING APRON 18" X 11" MSRP: Now: $67.67 Add to Cart Compare Quick view Formax sku: F515-6115 BLACK MAGIC ROUGE MSRP: Now: $21.49 Add to Cart Compare Quick view Formax sku: F515-6050 COATED ABRASIVE GREASE STICK GRADE F-26 MSRP: Now: $15.80 Add to Cart Compare Quick view Formax sku: F515-6051 COATED ABRASIVE GREASE STICK GRADE F-90 MSRP: Now: $15.80 Add to Cart Compare Quick view Formax sku: F515-6133 COLORING COMPOUND (MED GREASY) MSRP: Now: $15.80 Add to Cart Compare Quick view Formax sku: F515-6142 EXCELLO SS COMPOUND (MED GREASY) MSRP: Now: $21.49 Add to Cart Compare Quick view Formax sku: F515-6144 EXTRA FAST CUT SS COMPOUND (MED DRY) MSRP: Now: $21.49 Add to Cart Compare Quick view Formax sku: F515-6105 FAST CUT GREASY TRIPOLI COMPOUND MSRP: Now: $15.80 Add to Cart Compare Quick view Formax sku: F515-6141 FAST CUT SS COMPOUND (MED GREASY) MSRP: Now: $21.49 Add to Cart Compare Quick view Formax sku: F515-442 FLEX-A-GLU POLISHING WHEEL CEMENT 1 GAL MSRP: Now: $46.16 Add to Cart Compare Quick view Formax sku: F515-6272 GREEN MICRO FINE HONING COMPOUND - 20 OZ MSRP: Now: $39.84 Add to Cart Compare Quick view 80 GRIT LIQUID ABRASIVE SANDPAPER Coat your own abrasive surface with premixed, ready-to-use Liquid Abrasive Sandpaper®. Liquid Abrasive Sandpaper® contains fused aluminum oxide abrasive dispersed in synthetic glue. Use it for... MSRP: Now: $75.31 Add to Cart Compare Quick view ALL PURPOSE STAINLESS COMPOUND STAINLESS STEEL BUFFING WHEEL BAR COMPOUNDS FOR STAINLESS OR COLD ROLLED STEEL Stainless Compound is made of "alumina" and grease binders. Developed for use on stainless steel, its fast cutting and... MSRP: Now: $21.49 Add to Cart Compare Quick view ALUMINUM CUT & COLORING COMPOUND This grade was developed to "cut down" and "color" aluminum in one buffing operation on hand and automatic buffing machines. Brings up a high luster, leaving the buffed work clean and free of excess... MSRP: Now: $18.96 Add to Cart Compare Quick view ALUMINUM HIGH LUSTRE COMPOUND A very dry grade intended for buffing small work to a high luster. Will not pack intosmall cavities or recesses. If a brighter finish than No. A-14 Compound is desired,re-buff using A-15. 2" X 2" X... MSRP: Now: $18.96 Add to Cart Compare Quick view BELLY-PAD BUFFING APRON 18" X 11" BELLY-PAD BUFFING APRON The Belly-Pad Buffing apron is a covering designed to protect the polisher's body mid-section. It's made of heavy drill and twill cotton fabric, plied to 1/2" or more... MSRP: Now: $67.67 Add to Cart Compare Quick view BLACK MAGIC ROUGE A favorite for finishing brass, aluminum, copper, tin plate and other alloys. Will bring out a mirror-like luster on the work. Being a medium greasy grade it is ideal for the all around buffing job,... MSRP: Now: $21.49 Add to Cart Compare Quick view COATED ABRASIVE GREASE STICK GRADE F-26 ALL PURPOSE LUBRICANT FOR BELTS AND DISCSThis is the "original" and ever popular F-26 coated abrasive grease stick that is in universal use. The regular type polishing wheel grease sticks are... MSRP: Now: $15.80 Add to Cart Compare Quick view COATED ABRASIVE GREASE STICK GRADE F-90 ALL PURPOSE LUBRICANT FOR BELTS AND DISCSThis is the "original" and ever popular F-26 coated abrasive grease stick that is in universal use. The regular type polishing wheel grease sticks are... MSRP: Now: $15.80 Add to Cart Compare Quick view COLORING COMPOUND (MED GREASY) NON-FERROUS COLORING BAR COMPOUNDSSOMETIMES REFERRED TO AS WHITE OR BLACK DIAMOND BUFFING COMPOUND. Intended for buffing non-ferrous metals where the work surface is in good condition, free of deep... MSRP: Now: $15.80 Add to Cart Compare Quick view EXCELLO SS COMPOUND (MED GREASY) STAINLESS STEEL BUFFING WHEEL BAR COMPOUNDS FOR STAINLESS OR COLD ROLLED STEEL Stainless Compound is made of "alumina" and grease binders. Developed for use on stainless steel, its fast cutting and... MSRP: Now: $21.49 Add to Cart Compare Quick view EXTRA FAST CUT SS COMPOUND (MED DRY) STAINLESS STEEL BUFFING WHEEL BAR COMPOUNDS FOR STAINLESS OR COLD ROLLED STEEL Stainless Compound is made of "alumina" and grease binders. Developed for use on stainless steel, its fast cutting and... MSRP: Now: $21.49 Add to Cart Compare Quick view FAST CUT GREASY TRIPOLI COMPOUND This is a greasy, extra fast cutting grade of Tripoli containing a high percentage of aggressive abrasives combined with Tripoli Powder, which produces a fastercutting action. Used extensively on... MSRP: Now: $15.80 Add to Cart Compare Quick view FAST CUT SS COMPOUND (MED GREASY) STAINLESS STEEL BUFFING WHEEL BAR COMPOUNDS FOR STAINLESS OR COLD ROLLED STEEL Stainless Compound is made of "alumina" and grease binders. Developed for use on stainless steel, its fast cutting and... MSRP: Now: $21.49 Add to Cart Compare Quick view FLEX-A-GLU POLISHING WHEEL CEMENT 1 GAL A ready-to-use, water-soluble, synthetic adhesive for setting up polishing wheels and bobs made of cloth, canvas, felt, leather or wood. Apply by brushing on thin coats and rolling the wheel in a pan... MSRP: Now: $46.16 Add to Cart Compare Quick view GREEN MICRO FINE HONING COMPOUND - 20 OZ For Polishing, Lapping, Stropping and Honing Wood Working Tools to a micro fine razor sharp cutting edge. Also excellent for polishing leather with a felt wheel. MSRP: Now: $39.84 Add to Cart Compare 1 2 3 Next 1 2 3 Next Compare Selected × OK
