null
Additional Items Required
Get Our Plating Manual
Plug N' Plate® Brush Plating Kits
The great new way to brush plate small parts
Read An Article From Mac Life Magazine On Plating An iPod Using Our Plug N' Plate® Kits (372 KB PDF)
Read the Instruction Manual Here
Plug N' Plate Kit Contents
4 Simple Steps To Brush Plate Your Small Parts
1. Plug In The Adapter Plug In The Adapter
2. Clip the Black Lead To The Part Clip the Black Lead To The Part
3. Soak The Wand With Bandage In the Solution Soak The Wand With Bandage In the Solution
4. Brush The Wand Over The Cleaned Part Brush The Wand Over The Cleaned Part
Plug N' Plate® is a new concept in plating small parts. Our unique mains power pack supplies just the right amount of power allowing you to brush, and in some situations, dip plate your smaller components.
The Plug N' Plate® system will also allow you to patch repair areas where the original plating has worn away.
Plug N' Plate® is ideal for vintage vehicle restorers, antique collectors and dealers, and small workshops doing prototype work.
What could be simpler? The Plug N' Plate® wand is attached to the red plug on the Power Pack, and the alligator clip is attached to the work-piece. The end of the wand is covered in an absorbent bandage, which is soaked in the plating solution for a few seconds.
By simply stroking the part with swift brush strokes, the circuit is closed and the plating metal bearing solution goes to work, depositing its beautiful layer onto the object.
Plug N' Plate® is perfect for gold plating car emblems. Simply strip the chrome off with Chrome Stripper, then apply the gold. Full instructions are included.
Plug N' Plate® may be applied onto most metals. To see which kit plates onto which metal, read our instruction booklet. To plate onto Stainless Steel, use the Plug N' Plate® Copper system. When gold plating onto stainless, apply our Stainless Steel Activator For Gold with a stainless wand and 4.5V power pack, then you may gold plate directly onto the stainless part.
Aluminum can be plated with the Acid Copper Plug N Plate system, after prepping your part with Zincate.
Plastic parts can also be plated with our Acid Copper Plug N Plate system after painting with conductive paint and swabbed with Tinning Solution.
* - Manufacturer Direct Pricing. Plug N' Plate® is a registered trademark of Caswell Inc.
  • Plug N' Plate 14K Gold Kit Plug N' Plate 14K Gold Kit
    The great new way to brush plate small parts Video: Title Using The Caswell Plug N Plate Brush Plating Kit Read An Article From Mac Life Magazine On Plating An iPod Using Our Plug N' Plate® Kits (372 KB PDF) Read the Instruction Manual Here 4...
    $555.32
    Add to Cart
  • Plug N' Plate Fast Gold 24K Kit Plug N' Plate Fast Gold 24K Kit
    $555.32
    Add to Cart
  • Plug N' Plate FastGold 18K Kit Plug N' Plate FastGold 18K Kit
    $555.32
    Add to Cart
  • Plug N' Plate Rose Gold Kit Plug N' Plate Rose Gold Kit
    $555.32
    Add to Cart
  • Rose Gold Brush Plating Solution - 4 fl oz
    Rose Gold Brush Plating Solution For use with brush plating systems, including our Plug N Plate System. Use at 4.5-6 volts DC.  Cyanide Free. Contains over 1 pennyweight of gold per 4oz of solution, (2 troy oz per gallon) which enables the solution to...
    $542.67
    Add to Cart
  • FastGold Brush Plating Solution 14K - 4 fl oz FastGold Brush Plating Solution 14K - 4 fl oz
    FastGold 14 Karat FastGOLD is a new highly concentrated brush plating solution, designed especially for use with all types of brush plating machines, including pen platers. FastGOLD contains over 1 pennyweight of gold per 4oz of solution, (2 troy oz per...
    $541.41
    Add to Cart
  • Plug N' Plate Workshop Kit
    $346.60
    Add to Cart
  • Plug N' Plate Workshop Kit Gift Set Plug N' Plate Workshop Kit Gift Set
    Makes A Great Gift For Any Car or Bike Restorer, Jewelry Buff, Craftsman and more. Includes Gift Box The great new way to brush plate small parts Video: Title Using The Caswell Plug N Plate Brush Plating Kit Read An Article From Mac Life Magazine On...
    $332.68
    Add to Cart
  • Pen Plating Machine
    Pen Plating Machine
    For Pen/Brush Plating Includes spaces for three pens and three solutions. Will plate gold, silver, brass, nickel, copper and more.  Solutions Not Included. Use our Plug N Plate Solutions.
    $229.00
    Add to Cart
  • Plug N' Plate Black Krome/Gold Kit Plug N' Plate Black Krome/Gold Kit
    $125.22
    Add to Cart
  • Plug N' Plate Gold Emblem Plating & Stripping Kit Plug N' Plate Gold Emblem Plating & Stripping Kit
    Everything You Need To Gold Plate Car Emblems Includes Gold Plating System, Chrome Stripper and Nickel Activator Video: Title Using The Caswell Plug N Plate Brush Plating Kit Read An Article From Mac Life Magazine On Plating An iPod Using Our Plug N'...
    $125.22
    Add to Cart
  • Plug N' Plate Nickel/Gold Kit Plug N' Plate Nickel/Gold Kit
    $118.27
    Add to Cart
  • Plug N' Plate Gold Kit Plug N' Plate Gold Kit
    $104.35
    Add to Cart
  • PLUG N' PLATE GOLD SOLUTION
    Gold Plate car emblems, antiques, jewelry, coins, keepsakes, etc. Almost anything can be replated providing there is a nickel base. (Chrome plate has a nickel base). Gold solution has 4 month shelf life.
    $90.44
    Add to Cart
  • Plug N' Plate Brass Plating Kit
    $76.52
    Add to Cart
