null
Get Our Booklet
Sanding Supplies
  • 600 GRIT WET AND DRY PAPER
    Silicon Carbide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order packs of 100 to save!
    $0.54
    Add to Cart
  • Abrasive Wheel System Abrasive Wheel System
    LOW COST FLEXIBLE GRINDING WHEEL For use on your buffing machine! Much more abrasive than the toughest greaseless compounds Cuts through: PAINT, RUST, PLATING Grinds away: SHARP EDGES, PITS, SCRATCHES, Parting Lines, Mold Marks, Tool & Die MARKS,...
    $13.27
    Add to Cart
  • Aluminum Oxide 1 lb 120 Grit
    For use with buffing wheel cement. Apply cement evenly onto a buffing wheel, then lightly roll the wheel in the Aluminum Oxide grit of choice. Leave the coated wheel to air dry for several hours prior to use. Subsequent applications will provide a...
    $6.31
    Add to Cart
  • Aluminum Oxide 1 lb 180 Grit
    $6.31
    Add to Cart
  • Aluminum Oxide 1 lb 240 Grit
    $6.31
    Add to Cart
  • Aluminum Oxide 1 lb 320 Grit
    $6.31
    Add to Cart
  • Aluminum Oxide 1 lb 80 Grit
    $6.31
    Add to Cart
