Quick view Caswell sku: 4BMK65 1/2 - 3/4hp Motor Buffing Kit MSRP: Now: $114.47 Choose Options Compare Quick view Palmgren sku: BUFF115K 1/2 HP Buffing Machine Kit MSRP: Now: $285.88 Add to Cart Compare Quick view NotCHead sku: NTCHCA 1/2" COLLET FOR NOTCHEAD GRIP MSRP: Now: $50.54 Add to Cart Compare Quick view Palmgren sku: PG12HPB 1/2HP 3450 RPM Buffing Machine MSRP: Now: $240.35 Add to Cart Compare Quick view Palmgren sku: PG13HPB 1/2HP 3450 RPM Buffing Machine-1588154652 MSRP: Now: $226.44 Add to Cart Compare Quick view Caswell sku: 3BMK55 1/4 - 1/3hp Motor Buffing Kit MSRP: Now: $103.72 Choose Options Compare SALE Quick view Caswell sku: ST-7733K 1/4" AIR DIE GRINDER KIT MSRP: $87.29 Was: $87.29 Now: $49.99 Out of stock Compare Quick view Palmgren sku: PG10VSB 10" 1.5HP Variable Speed Buffer 900-3600 RPM MSRP: Now: $1,276.50 Add to Cart Compare Quick view Caswell sku: ESB120 120 GRIT SANDING BELT X 1 MSRP: Now: $3.15 Add to Cart Compare Quick view Caswell sku: ESB180 180 GRIT SANDING BELT X 1 MSRP: Now: $3.15 Add to Cart Compare Quick view Caswell sku: ESB240 240 GRIT SANDING BELT X 1 MSRP: Now: $3.15 Add to Cart Compare Quick view Caswell sku: 34HPBMKIT 3/4 HP Buffing Machine Kit - 3450 RPM MSRP: Now: $379.49 Add to Cart Compare Quick view Caswell sku: 10BMK135 3/4+hp Motor Buffing Kit 10" MSRP: Now: $156.85 Choose Options Compare Quick view Caswell sku: 1BMK129 3/4+hp Motor Buffing Kit 8" MSRP: Now: $143.57 Choose Options Compare Quick view Palmgren sku: PG34HPB 3/4HP 3450 RPM Buffing Machine MSRP: Now: $373.75 Add to Cart Compare Quick view 1/2 - 3/4hp Motor Buffing Kit 1/2-3/4hp Motor Buffing Kit 8" x 1/2" face 2 x Sisal Wheels 2 x Loose Wheels 2 x Spiral Sewn 1 x Buffing Rake 6 x Large Bars Compound (one of each) How to Buff & Polish Booklet MSRP: Now: $114.47 Choose Options Compare Quick view 1/2 HP Buffing Machine Kit Get the motor and a great starter buffing kit Kit includes : 1 x 1/2 hp buffing machine 2 x 6€ sisal wheels 2 x 6€ spiral sewn cotton wheels 2 x 6€ loose cotton wheels 1 large bar White compound 1... MSRP: Now: $285.88 Add to Cart Compare Quick view 1/2" COLLET FOR NOTCHEAD GRIP For use with the NotcHead Polishing Grip, this larger collet makes a valuable tool even more versatile. The soft aluminum jaws quickly grip the threads of the bolt so the head can be polished 360... MSRP: Now: $50.54 Add to Cart Compare Quick view 1/2HP 3450 RPM Buffing Machine Light Duty Cast Iron Buffing and Polishing Machine 1/2HP 3450RPM Motor 120/240V Easily remove scratches and other imperfections, brings out the natural luster of the metal, and can effectively... MSRP: Now: $240.35 Add to Cart Compare Quick view 1/2HP 3450 RPM Buffing Machine-1588154652 Light Duty Cast Iron Buffing and Polishing Machine 1/2HP 3450RPM Motor 120/240V Easily remove scratches and other imperfections, brings out the natural luster of the metal, and can effectively... MSRP: Now: $226.44 Add to Cart Compare Quick view 1/4 - 1/3hp Motor Buffing Kit 1/4 - 1/3hp Motor Buffing Kit 6" x 1/2" face 2 x Sisal Wheels 2 x Loose Wheels 2 x Spiral Sewn 1 x Buffing Rake 6 x Large Bars Compound (one of each) How to Buff & Polish Booklet MSRP: Now: $103.72 Choose Options Compare SALE Quick view 1/4" AIR DIE GRINDER KIT Grinder Specifications: Free Speed: 22000 RPM Capacity: 1/4" Overall Length: 6.25" Air lnlet (PT): 1/4" Air Hose(ID): 3/8" Air Consumption: 5 CFM Recommended Air Pressure: 90 PSI CE Certified 90 Day... MSRP: $87.29 Was: $87.29 Now: $49.99 Out of stock Compare Quick view 10" 1.5HP Variable Speed Buffer 900-3600 RPM These deluxe variable speed buffers deliver the power, precision and versatility to handle a wide range of finishing applications. At maximum rpm's they are built for intermediate blending, polishing... MSRP: Now: $1,276.50 Add to Cart Compare Quick view 120 GRIT SANDING BELT X 1 For use with the expander sanding wheel. Our Aluminum Oxide sanding belts fit all other brands of expanding wheels. MSRP: Now: $3.15 Add to Cart Compare Quick view 180 GRIT SANDING BELT X 1 For use with the expander sanding wheel. Our Aluminum Oxide sanding belts fit all other brands of expanding wheels. MSRP: Now: $3.15 Add to Cart Compare Quick view 240 GRIT SANDING BELT X 1 For use with the expander sanding wheel. Our Aluminum Oxide sanding belts fit all other brands of expanding wheels. MSRP: Now: $3.15 Add to Cart Compare Quick view 3/4 HP Buffing Machine Kit - 3450 RPM Includes Heavy Duty 3/4HP 3450 RPM Buffer, wheels and compounds for any metal. Each unit is equipped with a strong, powerful motor that supplies the necessary torque for start-up and operation under... MSRP: Now: $379.49 Add to Cart Compare Quick view 3/4+hp Motor Buffing Kit 10" 3/4+hp Motor Buffing Kit 10" x 7/8" face 2 x Sisal Wheels 2 x Loose (1/2" Face) Wheels 2 x Spiral Sewn 1 x Buffing Rake 6 x JUMBO Bars Compound (one of each) How to Buff & Polish Booklet MSRP: Now: $156.85 Choose Options Compare Quick view 3/4+hp Motor Buffing Kit 8" 3/4+hp Motor Buffing Kit 8" x 7/8" face 2 x Sisal Wheels 2 x Loose Wheels (1/2" Face) 2 x Spiral Sewn 1 x Buffing Rake 6 x JUMBO Bars Compound (one of each) How to Buff & Polish Booklet MSRP: Now: $143.57 Choose Options Compare Quick view 3/4HP 3450 RPM Buffing Machine Heavy Duty Cast Iron Buffing and Polishing Machine 3/4HP 3450RPM Motor 120/240V Easily remove scratches and other imperfections, brings out the natural luster of the metal, and can effectively... MSRP: Now: $373.75 Add to Cart Compare 1 2 3 4 5 6 Next 1 2 3 4 5 6 Next Compare Selected × OK
