null
Everything For Firearms
  • ALUMINUM BLACKENER A385
    Aluminum Blackener A385 Ideal For Touching Up Black Anodized Parts Vary the color from a rich pewter gray to a deep black by changing dilution and immersion times. Completely colorfast through age or...
    $31.61
    Add to Cart
  • Black Oxide Gel Kit
    Black Oxide Gel Kit
    Easily spot blacken steel (not stainless) or iron. Simply apply the black oxide gel where you want the blackening to occur. The gel keeps the blackener in place. Leave it on the part for 1-3 minutes...
    $31.61
    Add to Cart
  • Black Oxide Kit - 1.25 Gal Black Oxide Kit - 1.25 Gal
    Blacken Steel Or Iron Parts At Room Temperature This new technique was developed by the commercial gun blue manufacturers as a more environmentally friendly system than the commonly used hot...
    $102.34
    Choose Options
  • Black Oxide Kit - 2.5 Gal Black Oxide Kit - 2.5 Gal
    Blacken Steel & Iron Parts At Room Temperature This new technique was developed by the commercial gun blue manufacturers as a more environmentally friendly system than the commonly used hot...
    $188.59
    Choose Options
  • CHARGED WALNUT SHELL - 5 LB
    Rouge-treated Walnut shell Non-abrasive rouge used dry Dry coloring media for final finish 3rd step in finishing process. Leaves some rouge residue Cycle Time: 5-15 hours
    $33.51
    Add to Cart
  • Cyclone Parts Dryer
    Cyclone Parts Dryer
    Blackening Parts? Need Fast Part Drying? The Cyclone Parts Dryer speeds up the drying process, helps prevent flash rusting and dries without water spots Features 11€ x 10€ x 13€ One inch tray depth...
    $125.24
    Add to Cart
  • DuraBlue Nitre Aerosol Kit
    DuraBlue Nitre Aerosol Kit Spray On Nitre Bluing Get The Sought-After Look of Nitre Bluing Also known as Fire Blue, Nitre Bluing was historically seen on small parts of handguns and long guns. The...
    $63.19
    Out of stock
  • FELT WHEEL - HARD 6 X 1
    Ideal for many uses including woodworking, gunsmithing, knife sharpening, jewelry work etc. These firm felt wheels won't splay out or fray, making them ideal for the applications above. Long lasting...
    $36.29
    Out of stock
  • FELT WHEEL - HARD 6 X 3/4
    $26.94
    Add to Cart
  • FELT WHEEL - MEDIUM 6 X 1
    $30.24
    Add to Cart
  • FELT WHEEL - MEDIUM 6 X 1/2"
    $15.94
    Add to Cart
  • FELT WHEEL - MEDIUM 6 X 3/4
    $24.19
    Add to Cart
