BELLY-PAD BUFFING APRON 18" X 11"
The Belly-Pad Buffing apron is a covering designed to protect the polisher's body mid-section. It's made of heavy drill and twill cotton fabric, plied to 1/2" or more thickness and sturdily sewn. Straps of long-length, nylon, seat-belt webbing, with plastic buckles, provide ample adjustment for all girths. 18" Wide x 11" Deep
