|   Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The large bars are 1.25" x 1.25" x 6" and weigh approx. 1.5 lb. each. We believe these industrial size bars represent a better value than the packaged tubes being marketed.  |
SDS
4 Reviews Hide Reviews Show Reviews
Quality compound
Nice even consistancy! I've used other brands and have had inconsistant chunks of abrasive. Not the case with this stuff.
Repeat customer
Great products and service
excellent
works great
works great
Buffs the pens that I turn to a glass like finish.
