For best performance, and to make your greaseless compound last longer on the buff, treat the wheel with Glu-Tite before applying the compound.
6 Reviews Hide Reviews Show Reviews
Worked as specified
Recommended as an initial bonding agent when setting up a wheel with greaseless compounds.
A must for using greaseless compounds
The prep will ensure your greaseless compounds go a bit further while using, definitely worthwhile to pick up!
It was free with points!
Haven't used it yet but its from Caswell so I know it will work.
As advertised
Good Product
Works as advertised
This product is must have if y0u are working with greaseless compounds. It makes them stick and stay stuck to the wheel.
Really extends the life of geasless compunds!
I Absoultely love this stuff!!! I have tired with and without. I notice a hughe difference in length of time in having to reapply with use! Won't be using without period!!!!
