GREASELESS COMPOUNDS - Greaseless Buffing compounds may be applied to almost any cloth buffing wheel, (sisal, spiral sewn cotton & loose cotton) turning it into a tough flexible grinding wheel. The roughest casting edges can quickly removed. These materials do an excellent job of leveling highly contoured surfaces quickly.
Store at room temperature or below.
We recommend shipping these products by air during summer months to ensure the product does not melt during shipping.
For best performance, and to make your greasless compound last longer on the buff, treat the wheel with Glu-Tite before applying the compound.
Â
3 Reviews Hide Reviews Show Reviews
As advertised
Good Product
Great stuff
Does what its supposed to do!
Nice compound
Flows on to the wheel better than the 80 grit version. Works nice with either a cotton or sisal wheel.
