Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The large bars are 1.25" x 1.25" x 6" and weigh approx. 1.5 lb. each. We believe these industrial size bars represent a better value than the packaged tubes being marketed. |
SDS
16 Reviews Hide Reviews Show Reviews
i had been using something from Vintage Trailer...it just wasn't cutting it...... these bars, used in conjunction with the sisal wheels, are saving me plenty of time.
nice
fast shipping
Aluminum mirror finish
I bring my large aluminum plate sculptures from mill to mirror finsh. Once I've gone through a set of different grit sand papers, I use the black compound with an angle grinder and spiral sewn wheel to get the mirror finish. This stuff is perfect and the size is great for what I do. I love the Caswell guys - they ship fast and their customer support has gotten me out of tight spots.
excellent
I work on large aluminum sculptures that I take from mill to mirror finish by hand. I go through a lot of emery and these bars are perfect for that. After I've gone through several grits of sandpaper all the way to 1000, I switch to Black Buffing Compound which brings out the mirror beautifully.
Great
We needed this to polish our 1965 Airstream Trailer. It is working great.
Excellent
Perfect for beginning to cut metals
perfect fit!
Awesome : )
perfect fit!
Awesome : )
Better than ever!
I've always been happy with your buffing compounds. Now I'm happier -- the new cardboard wrapping works great! My bars arrived in perfect condition. Thanks for all you do! I've been a satisfied Caswell customer for several years and have no plans to shop elsewhere.
