BLACK BUFFING COMPOUND LARGE
Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The large bars are 1.25" x 1.25" x 6" and weigh approx. 1.5 lb. each. We believe these industrial size bars represent a better value than the packaged tubes being marketed. |
SDS
8 Reviews Hide Reviews Show Reviews
It gets the polishing off to a great start
I've been using one of these with a 6" sisal wheel to begin polishing stainless bar and tube after removing scale and blemishes with flapper wheels down to 120 grit. It is very effective at removing the fine scratches from the flapper wheel and quickly prepares the surface for the next stage of polishing with a green compound.
Excellent service.
Will buy from them again.
works good on stainless four link suspension bars for removing scratches
easy to use and cleans up scratches quickly
Quality compound
Nice even consistancy! I've used other brands and have had inconsistant chunks of abrasive. Not the case with this stuff.
professional grade
Another fine Caswell professional grade product.
GREAT CUTTER
BOUGHT THIS IN JUMBO AND WORKS GREAT!!
Okay product
What can I say here. It is a buffing compound that works fine. No problems with this product
Will buy again
Great company to deal with. Fast shipping and great prices!
