GREASELESS COMPOUNDS - Greaseless Buffing compounds may be applied to almost any cloth buffing wheel, (sisal, spiral sewn cotton & loose cotton) turning it into a tough flexible grinding wheel. The roughest casting edges can quickly removed. These materials do an excellent job of leveling highly contoured surfaces quickly.
Store at room temperature or below.
We recommend shipping these products by air during summer months to ensure the product does not melt during shipping.
For best performance, and to make your greasless compound last longer on the buff, treat the wheel with Glu-Tite before applying the compound.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
4 Reviews Hide Reviews Show Reviews
As advertised
Good Product
Fast Shipping, exactly as described.
Excellent product, does exactly what it is supposed to do. Beats sanding by hand , much, much faster!!!
Excellent
Only issue is they get harden and you cannot use them anymore? Any help how to keep them that they won't get hardened? thank you
Cuts great and leaves a satin finish.
Nice compound to work with. Just don't forget to close it up when you're done.
