null
Metal Strippers
  • ANODIZE & CHROME  STRIPPER - 8 OZ
    8 fl oz of stripping solution. To strip anodize, immerse parts for 5-30 minutes. To strip chrome, use a stainless steel wand and 12V DC. Contains Hazardous Goods. Shipping restrictions apply. Ground shipping only to the Continental USA. Please call +1...
    $8.84
    Add to Cart
  • B9 NICKEL STRIPPER - 2.5 LB
    NO ELECTRICITYNO CYANIDESNO PHOSPHATESNO CAUSTIC AMINESNO AMMONIANO FUMES The only one-component, non-toxic, powdered, immersion nickel strippers on the market. Removes NICKEL from steel, copper, brass and zinc diecast, silver and gold. Caswell Inc...
    $37.94
    Add to Cart
  • B9 NICKEL STRIPPER - 5 LB
    NO ELECTRICITYNO CYANIDESNO PHOSPHATESNO CAUSTIC AMINESNO AMMONIANO FUMES   The only one-component, non-toxic, powdered, immersion nickel strippers on the market. Removes NICKEL from steel, copper, brass and zinc diecast, silver and gold. Caswell...
    $60.08
    Add to Cart
  • B913 NICKEL STRIPPER FOR ALUMINUM 2.5 LB
    $37.94
    Add to Cart
  • B913 NICKEL STRIPPER FOR ALUMINUM 5 LBS
    p align="center">NO ELECTRICITYNO CYANIDESNO PHOSPHATESNO CAUSTIC AMINESNO AMMONIANO FUMES The only one-component, non-toxic, powdered, immersion nickel strippers on the market. Removes NICKEL from steel, copper, brass and zinc diecast, silver and...
    $60.08
    Add to Cart
  • B929 NICKEL STRIPPER 2.5 LBS
    $37.94
    Add to Cart
  • B929 NICKEL STRIPPER 5 LBS
    $60.08
    Add to Cart
  • Caswell Stripping Kit - 5 Gal
    A Complete Kit For Stripping Chrome, Nickel and Copper From Steel, Aluminum and Plastics Triple Chrome plated parts have a layer of chrome, nickel and copper plates over the base metal. To remove all the plating from these parts usually involves buffing...
    $624.90
    Add to Cart
  • Copper Stripping Kit - 1 Gal
    Copper Stripping Kit The copper stripping kit contains everything you need, except a DC power supply, to strip copper from aluminum and steel. 1 Gallon Kit Contains: 2 Gallon Tank and Lid 2.5 lbs MetalX Copper Stripper (makes 1 gallon) 2 x Stainless...
    $123.96
    Add to Cart
  • Copper Stripping Kit - 2 Gal
    Copper Stripping Kit The copper stripping kit contains everything you need, except a DC power supply, to strip copper from aluminum and steel. 1 Gallon Kit Contains: 3.5 Gallon Tank and Lid 5 lbs MetalX Copper Stripper (makes 2 gallons) 2 x Stainless...
    $151.79
    Add to Cart
  • Electrocleaning Kit - 3 Gal
    Caswell Electrocleaning Kit Electrocleaning is a highly effective and fast way of cleaning parts prior to plating. It will remove oils, rust, grease and even paint. The part to be cleaned is hung into the cleaning solution and then connected to the...
    $113.85
    Choose Options
  • METAL X COPPER STRIPPER
    MetalX Copper Stripper is an electrical copper stripper with the exceptional ability to throw into very deep recesses. It also has the ability to plate out the stripped copper making the bath last indefinitely. It contains no ammonia or ammonia compounds...
    $48.69
    Add to Cart
  • Plug N' Strip Chrome Stripping Kit
    The great new way to strip chrome from small parts     Now you can strip chrome off small parts without having to purchase a large stripping setup. Our Plug N' Strip™ kit will easily remove chrome layers from any part by simply plugging...
    $56.35
    Add to Cart
