Quick view NotCHead sku: NTCHCA 1/2" COLLET FOR NOTCHEAD GRIP MSRP: Now: $43.95 Add to Cart Compare Quick view Palmgren sku: PG12HPB 1/2HP 3450 RPM Buffing Machine MSRP: Now: $209.00 Add to Cart Compare Quick view Palmgren sku: PG13HPB 1/2HP 3450 RPM Buffing Machine-1588154652 MSRP: Now: $196.90 Add to Cart Compare Quick view Palmgren sku: PG10VSB 10" 1.5HP Variable Speed Buffer 900-3600 RPM MSRP: Now: $1,110.00 Add to Cart Compare Quick view Palmgren sku: PG34HPB 3/4HP 3450 RPM Buffing Machine MSRP: Now: $325.00 Add to Cart Compare Quick view Palmgren sku: PG6VSB 6" 3/4HP Variable Speed Buffer 900-3600 RPM MSRP: Now: $459.00 Out of stock Compare Quick view Palmgren sku: PG8VSB 8" 1HP Variable Speed Buffer 900-3600 RPM MSRP: Now: $619.00 Out of stock Compare Quick view Baldor sku: BD111 BALDOR 1/3 HP 3600 RPM BUFFER MSRP: Now: $432.30 Add to Cart Compare Quick view Baldor sku: BD407B Baldor 1HP 1800RPM Buffer 115 VAC/60Hz MSRP: Now: $1,126.40 Add to Cart Compare Quick view Baldor sku: BD1251 BALDOR 2 HP 3600 RPM BUFFER MSRP: Now: $2,535.50 Add to Cart Compare Quick view Baldor sku: BD332B BALDOR 3/4 HP 1800 RPM BUFFER MSRP: Now: $849.20 Add to Cart Compare Quick view Baldor sku: BD333B BALDOR 3/4 HP 3600 RPM BUFFER MSRP: Now: $849.20 Add to Cart Compare Quick view Baldor sku: G8-0390-0364 Baldor 3/4-1/2HP 3600/1800 RPM Buffer 115 VAC/60Hz MSRP: Now: $1,419.00 Add to Cart Compare Quick view Baldor sku: BD1253 BALDOR 3HP 3000/3600RPM BUFFER MSRP: Now: $2,328.70 Add to Cart Compare Quick view Baldor sku: BDGA16 BALDOR PEDESTAL FOR 1/4HP-1-1/2HP BUFFER MSRP: Now: $537.90 Add to Cart Compare Quick view 1/2" COLLET FOR NOTCHEAD GRIP For use with the NotcHead Polishing Grip, this larger collet makes a valuable tool even more versatile. The soft aluminum jaws quickly grip the threads of the bolt so the head can be polished 360 without damage. It secures the bolt evenly with a... MSRP: Now: $43.95 Add to Cart Compare Quick view 1/2HP 3450 RPM Buffing Machine Light Duty Cast Iron Buffing and Polishing Machine 1/2HP 3450RPM Motor 120/240V Easily remove scratches and other imperfections, brings out the natural luster of the metal, and can effectively clean, polish, finish, and buff a wide variety of... MSRP: Now: $209.00 Add to Cart Compare Quick view 1/2HP 3450 RPM Buffing Machine-1588154652 Light Duty Cast Iron Buffing and Polishing Machine 1/2HP 3450RPM Motor 120/240V Easily remove scratches and other imperfections, brings out the natural luster of the metal, and can effectively clean, polish, finish, and buff a wide variety of... MSRP: Now: $196.90 Add to Cart Compare Quick view 10" 1.5HP Variable Speed Buffer 900-3600 RPM These deluxe variable speed buffers deliver the power, precision and versatility to handle a wide range of finishing applications. At maximum rpm's they are built for intermediate blending, polishing and surface conditioning applications. At the lower... MSRP: Now: $1,110.00 Add to Cart Compare Quick view 3/4HP 3450 RPM Buffing Machine Heavy Duty Cast Iron Buffing and Polishing Machine 3/4HP 3450RPM Motor 120/240V Easily remove scratches and other imperfections, brings out the natural luster of the metal, and can effectively clean, polish, finish, and buff a wide variety of... MSRP: Now: $325.00 Add to Cart Compare Quick view 6" 3/4HP Variable Speed Buffer 900-3600 RPM These deluxe variable speed buffers deliver the power, precision and versatility to handle a wide range of finishing applications. At maximum rpm's they are built for intermediate blending, polishing and surface conditioning applications. At the lower... MSRP: Now: $459.00 Out of stock Compare Quick view 8" 1HP Variable Speed Buffer 900-3600 RPM These deluxe variable speed buffers deliver the power, precision and versatility to handle a wide range of finishing applications. At maximum rpm's they are built for intermediate blending, polishing and surface conditioning applications. At the lower... MSRP: Now: $619.00 Out of stock Compare Quick view BALDOR 1/3 HP 3600 RPM BUFFER Made In The USA by Baldor Electric Co. These industrial buffing machines are the cream of the crop, and are covered by the manufacturer's 3 year warranty. We sell the complete range of Baldor buffers. If you want an item you don't see here, please... MSRP: Now: $432.30 Add to Cart Compare Quick view Baldor 1HP 1800RPM Buffer 115 VAC/60Hz Made In The USA by Baldor Electric Co. Includes flanges and nutsShipping Weight: 60lbsShaft Diameter: .875""Horsepower: 1Voltage: 115Hertz: 60Phase: 1Amps: 5.4RPM: 1800 Max Wheel Size: 10 inchesWheel Width Min/Max: 0.38"/1.25"Bearings: 6206UL Listed:... MSRP: Now: $1,126.40 Add to Cart Compare Quick view BALDOR 2 HP 3600 RPM BUFFER Made In The USA by Baldor Electric Co. These industrial buffing machines are the cream of the crop, and are covered by the manufacturer's 3 year warranty. We sell the complete range of Baldor buffers. If you want an item you don't see here, please... MSRP: Now: $2,535.50 Add to Cart Compare Quick view BALDOR 3/4 HP 1800 RPM BUFFER Made In The USA by Baldor Electric Co. These industrial buffing machines are the cream of the crop, and are covered by the manufacturer's 3 year warranty. We sell the complete range of Baldor buffers. If you want an item you don't see here, please... MSRP: Now: $849.20 Add to Cart Compare Quick view BALDOR 3/4 HP 3600 RPM BUFFER Made In The USA by Baldor Electric Co. These industrial buffing machines are the cream of the crop, and are covered by the manufacturer's 3 year warranty. We sell the complete range of Baldor buffers. If you want an item you don't see here, please... MSRP: Now: $849.20 Add to Cart Compare Quick view Baldor 3/4-1/2HP 3600/1800 RPM Buffer 115 VAC/60Hz Made In The USA by Baldor Electric Co. These industrial buffing machines are the cream of the crop, and are covered by the manufacturer's 3 year warranty. We sell the complete range of Baldor buffers. If you want an item you don't see here, please... MSRP: Now: $1,419.00 Add to Cart Compare Quick view BALDOR 3HP 3000/3600RPM BUFFER Made In The USA by Baldor Electric Co. Includes flanges and nutsShipping Weight: 156 lbsShaft Diameter: 1.25""Horsepower: 3Voltage: 230Hertz: 60Phase: 3Amps: 7.4 ampsRPM: 3000/3600Max Wheel Size: 2 inchesWheel Width Min/Max: 0.38"/2"Bearings: 6206UL... MSRP: Now: $2,328.70 Add to Cart Compare Quick view BALDOR PEDESTAL FOR 1/4HP-1-1/2HP BUFFER Made In The USA by Baldor Electric Co. These industrial buffing machines are the cream of the crop, and are covered by the manufacturer's 3 year warranty. We sell the complete range of Baldor buffers. If you want an item you don't see here, please... MSRP: Now: $537.90 Add to Cart Compare 1 2 Next 1 2 Next Compare Selected × OK
