null
Get Our Booklet
Paint Buffing System
No Swirl Marks or Holograms
Axial motion of the pad eliminates circular micro-marring leaving a professional swirl-free shine every time.
Reduces Labor
Up to a 50% improvement in efficiency making every job fast and effective saving time and money.
Ease of Use / Peace of Mind
High speed adjustable operation giving you the heat and friction you want without the required training to master.
Dual Pistol Grip Handles
Ergonomically designed hand grips minimizing awkward wrist positioning and hand fatigue.
Minimizes Mess and Splatter
Cylindrical pad keeps compounds under the buffer reducing the use of chemicals and minimizing the need to mask.
Pads Stay Cleaner Longer
Centrifugal force keeps polish on the outside of the pad so it won’t load up with compound like traditional orbiters.
Multiple Pad Options
Available pads include options for Cutting, Polishing, Finishing and even Sanding.
Industrial Grade Motor
An electrically operated motor, heat treated precision-cut gears, and a variable speed locking trigger. Great for mobile situations or shops.
  • BuffPro Finishing Pad
    BuffPro  Finishing Pad The Finishing Pad for BuffPro® Model JF180 Axial Polisher, is an open cell polyester foam pad that works with your mildest finishing compounds to provide unparalleled...
    $74.75
    Add to Cart
  • BUFFPRO HEAVY CUT WOOL PAD
    BuffPro® Pad | Heavy Cut Wool Pad The Heavy Cutting Wool Pad for BuffPro® Model JF180 Axial Polisher, is a fine wool material over a foam pad that works with your most aggressive compounds to...
    $112.70
    Add to Cart
  • BUFFPRO MEDIUM CUTTING PAD
    Medium Cutting Pad The Medium Cutting Pad for BuffPro® Model JF180 Axial Polisher, is an open cell polyester foam pad that works with your most aggressive compounds to provide unparalleled...
    $74.75
    Add to Cart
  • BuffPro Polishing Pad
    Polishing Pad The Polishing Pad for BuffPro® Model JF180 Axial Polisher, is an open cell polyester foam pad that works with your milder finishing compounds to provide unparalleled polishing and...
    $74.75
    Add to Cart
  • Glare Hurricane Pads (Set of 6)
    The Hurricane Pads are made with the highest Reticulated German engineered foam and designed like no other pad. Keeps the polish in front of the pad instead of seeping to the back, which keeps the...
    $158.07
    Add to Cart
