Quick view Caswell sku: GPS5215 24CT GOLD PLATING SOLUTION - 1 GAL MSRP: Now: $1,449.00 Add to Cart Compare Quick view Caswell sku: ALDEOX10G Aluminum De-Oxidizer & De-Smut 5 Gal - Makes 40 Gals MSRP: Now: $411.75 Add to Cart Compare Quick view Caswell sku: ALDG10 Aluminum Degreaser Powder - 10 lb Makes 15 Gallons MSRP: Now: $153.05 Add to Cart Compare Quick view Caswell sku: ALDG Aluminum Degreaser Powder - 2lb Makes 3 Gallons MSRP: Now: $34.78 Add to Cart Compare Quick view Caswell sku: BKS1G BLACK KROME PLATING SOLUTION 1 GAL MSRP: Now: $115.74 Add to Cart Compare Quick view Caswell sku: BANOD22 BRASS ANODE MSRP: Now: $36.67 Add to Cart Compare Quick view Caswell sku: BANOD110 BRASS ANODE 18 X 20" MSRP: Now: $441.47 Add to Cart Compare Quick view Caswell sku: EZPLATE Caswell One-Plate® 1 Electroless Nickel Solution MSRP: Now: $51.74 Choose Options Compare Quick view Caswell sku: FCB8 CHEMICAL MIST SUPPRESSANT (For Chrome Plating) MSRP: Now: $17.07 Add to Cart Compare Quick view Caswell sku: GPPL1750 CHROME ANODES 12 X 12 MSRP: Now: $68.43 Add to Cart Compare Quick view Caswell sku: CUANOD20 COPPER ANODE .032" x 4"x 8" MSRP: Now: $27.82 Add to Cart Compare Quick view sku: CUBRA1Q COPPER BRIGHTENER PART A - 1 QT MSRP: Now: $54.38 Add to Cart Compare Quick view Caswell sku: CUBRA COPPER BRIGHTENER PART A - 1.5 OZ MSRP: Now: $6.95 Add to Cart Compare Quick view sku: CUBRB1Q COPPER BRIGHTENER PART B - 1 QT MSRP: Now: $68.30 Add to Cart Compare Quick view Caswell sku: CUBRB COPPER BRIGHTENER PART B - 4 OZ MSRP: Now: $10.11 Add to Cart Compare Quick view 24CT GOLD PLATING SOLUTION - 1 GAL Caswell 24ct Gold will plate directly onto tin, copper, brass, bronze, nickel, silver and most lead free solders. Some alloys must be copper or nickel plated first. Steel must be nickel plated first. Contains 2 pennyweights gold per US Gallon of solution. MSRP: Now: $1,449.00 Add to Cart Compare Quick view Aluminum De-Oxidizer & De-Smut 5 Gal - Makes 40 Gals Mix 1 Quart Into 2 Gals Distilled Water In a HDPE Tank. Always add into water. Never add water into this product.Operate at 70-110 deg F. Immerse aluminum part for 1-3 minutes. MSRP: Now: $411.75 Add to Cart Compare Quick view Aluminum Degreaser Powder - 10 lb Makes 15 Gallons This special degreaser for Aluminum quickly cleans any aluminum alloy without etching. Mix 10 lbs of cleaner with 15 gallons of distilled water in a stainless steel container. Heat to 130 deg F on a hotplate. Immerse aluminum parts for 3-10 minutes prior... MSRP: Now: $153.05 Add to Cart Compare Quick view Aluminum Degreaser Powder - 2lb Makes 3 Gallons This special degreaser for Aluminum quickly cleans any aluminum alloy without etching. Mix 2 lbs of cleaner with 3 gallons of distilled water in a stainless steel container. Heat to 130 deg F on a hotplate. Immerse aluminum parts for 3-10 minutes prior... MSRP: Now: $34.78 Add to Cart Compare Quick view BLACK KROME PLATING SOLUTION 1 GAL Use to replenish or add onto an existing Black Krome plating kit. Use as is. Do not dilute. MSRP: Now: $115.74 Add to Cart Compare Quick view BRASS ANODE Brass Anode - 4" x 8" x 0.020" MSRP: Now: $36.67 Add to Cart Compare Quick view BRASS ANODE 18 X 20" Brass Anode - 18" x 20" MSRP: Now: $441.47 Add to Cart Compare Quick view Caswell One-Plate® 1 Electroless Nickel Solution Caswell One-Plate® 1 – Electroless Nickel Made Easy Caswell One-Plate® 1 Electroless Nickel is truly a revolution for small scale Electroless Nickel plating. No more mixing of multiple chemicals, simpler one solution additions, lower... MSRP: Now: $51.74 Choose Options Compare Quick view CHEMICAL MIST SUPPRESSANT (For Chrome Plating) A chemical frothy blanket that actually floats on top of the chrome, virtually eliminates all misting when used with Fume Control Balls. Use one bottle per 2 sq ft of plating tank surface area.Note: Mist Suppressant is now premixed into our chrome... MSRP: Now: $17.07 Add to Cart Compare Quick view CHROME ANODES 12 X 12 For use with our Hard Chrome kits. MSRP: Now: $68.43 Add to Cart Compare Quick view COPPER ANODE .032" x 4"x 8" Copper Anode 4" x 8" MSRP: Now: $27.82 Add to Cart Compare Quick view COPPER BRIGHTENER PART A - 1 QT Treats 12 Gallons of Acid Copper plating solution. Add when making up copper solution for the first time. MSRP: Now: $54.38 Add to Cart Compare Quick view COPPER BRIGHTENER PART A - 1.5 OZ Treat 1.5 gallons. Add when making up copper solution for the first time. MSRP: Now: $6.95 Add to Cart Compare Quick view COPPER BRIGHTENER PART B - 1 QT Add 1 floz Copper Brightener Part B per 5 Gals Initial Bath Acid Copper Plating Solution Add 0.1-0.3 floz Copper Brightener Part B as required to maintain brightness. MSRP: Now: $68.30 Add to Cart Compare Quick view COPPER BRIGHTENER PART B - 4 OZ Add 0.3 floz Copper Brightener Part B per 1.5 Gals Initial Bath Copper Plating Solution Add 0.1-0.3 floz Copper Brightener Part B as required to maintain brightness. MSRP: Now: $10.11 Add to Cart Compare 1 2 3 4 5 6 Next 1 2 3 4 5 6 Next Compare Selected × OK
