null
Cartridge Case Polishing
Vibratory tumbling is an economical mass finishing technique which gives you a more uniform finish on large quantities of parts in much less time than standard hand finishing, without the mess. It holds the overall shape of the pieces better and allows you to check the progress of the work without stopping the unit. Compact, yet durable, these vibratory tumblers are donut shaped for uniform polishing & maximum coverage, The heavy polyethylene bowls remove easily and quickly for emptying.
To easily polish your brass cartridges, start with the walnut shell media, then switch to corn cob for the final polish. Add Flitz Tumbler/Media Additive to cut your polish times in half.
Ball-bearing motors operate at relatively low noise levels, have thermal overload protection and are 3000rpm @ 60Hz. One year warranty. Made in USA.
Replacement Bowls are available - ask for prices
