null
Vibratory Tumblers and Media
Vibratory tumbling is an economical mass finishing technique which gives you a more uniform finish on large quantities of parts in much less time than standard hand finishing, without the mess. It holds the overall shape of the pieces better and allows you to check the progress of the work without stopping the unit. Compact, yet durable, these vibratory tumblers are donut shaped for uniform polishing & maximum coverage, The heavy polyethylene bowls remove easily and quickly for emptying.
One year warranty. Made in USA.
Replacement Bowls are available - ask for prices
The selection of media and compounds shown below are specifically designed to accomplish the finishing needs of the small plating shop.
Proper selection is important to achieve the desired results.For more information, read this article.
  • CHARGED WALNUT SHELL - 5 LB
    Rouge-treated Walnut shell Non-abrasive rouge used dry Dry coloring media for final finish 3rd step in finishing process. Leaves some rouge residue Cycle Time: 5-15 hours
    $33.51
    Add to Cart
  • VIBRATORY TUMBLER - ADJUSTA-VIBE 18
    Heavy duty & adjustable for all medias The AV-18 has capacity of .18 cubic feet (5.3 Quarts). It has adjustable amplitude and is designed for heavy duty use with all medias. The 12-inch bowl is equipped with drains. This model has many features of our...
    $626.18
    Add to Cart
  • VIBRATORY TUMBLER - ADJUSTA-VIBE 40
    Compact with adjustable amplitude Model 40 vibratory machines are compact, yet have a capacity of .35 cubic feet (10.4 quarts) and are equipped with amplitude adjustment, inlet and outlet ports for compound rinsing systems and heavy duty cross-linked...
    $1,480.05
    Add to Cart
  • VIBRATORY TUMBLER - ADJUSTA-VIBE 75
    Heavy duty & adjustable amplitude The AV-75 is a .75 cubic foot (5.6 Gallon) capacity machine that offers increased productivity over other models. The machine is equipped with a heavy duty drive system that includes amplitude adjustment and the same ...
    $1,802.63
    Add to Cart
  • VIBRATORY TUMBLER - TUMBLE VIBE 10
    Heavy duty finishing & rinsing The industrial model TV-10 has heavy duty drive and suspension combined with a tough, cross-linked polyethylene 10 inch bowl. Bowl capacity is .10 cubic feet (35 to 40 rings), has a noise reducing lid and a liquid drain...
    $302.34
    Add to Cart
