Quick view Caswell sku: CB4 32 PLY CUSHION BUFF - 4 Inch MSRP: Now: $10.34 Out of stock Compare Quick view Caswell sku: CB6 32 PLY CUSHION BUFF - 6 Inch MSRP: Now: $14.94 Out of stock Compare Quick view Caswell sku: CB8 32 PLY CUSHION BUFF - 8 Inch MSRP: Now: $17.24 Choose Options Compare Quick view Caswell sku: BRSMW1 BRASS WIRE SHANK MOUNTED WHEEL MSRP: Now: $3.78 Add to Cart Compare Quick view Caswell sku: CFW10 CANTON FLANNEL WHEEL - 10" X 1/2" MSRP: Now: $8.79 Choose Options Compare Quick view Caswell sku: CF14 CANTON FLANNEL WHEEL 14" x 1/2" MSRP: Now: $12.09 Out of stock Compare Quick view Caswell sku: CFW43 CANTON FLANNEL WHEEL 4 X 1/2 MSRP: Now: $3.84 Choose Options Compare Quick view Caswell sku: CFW64 CANTON FLANNEL WHEEL 6 X 1/2 MSRP: Now: $4.94 Choose Options Compare Quick view Caswell sku: CFW87 CANTON FLANNEL WHEEL 8 X 1/2 MSRP: Now: $7.14 Choose Options Compare Quick view sku: CFBS8 CLOTH FINGER BUFF - SOFT MSRP: Now: $11.37 Choose Options Compare Quick view Caswell sku: DB4 DENIM BUFFING WHEEL - 4" x 1/2" MSRP: Now: $7.69 Choose Options Compare Quick view Caswell sku: DB6 DENIM BUFFING WHEEL - 6" x 1/2" MSRP: Now: $8.79 Out of stock Compare Quick view Caswell sku: DB8 DENIM BUFFING WHEEL - 8" x 1/2" MSRP: Now: $12.09 Out of stock Compare Quick view Caswell sku: DF4 DOMET FLANNEL WHEEL - 4" X 1/2" MSRP: Now: $3.84 Choose Options Compare Quick view Caswell sku: DF6 DOMET FLANNEL WHEEL - 6" X 1/2" MSRP: Now: $4.94 Choose Options Compare Quick view 32 PLY CUSHION BUFF - 4 Inch These buffs are sewn with two rows to slightly stiffen the buff. This improves the speed of the final coloring operation, giving you performance somewhere between a spiral sewn and a loose wheel. MSRP: Now: $10.34 Out of stock Compare Quick view 32 PLY CUSHION BUFF - 6 Inch These buffs are sewn with two rows to slightly stiffen the buff. This improves the speed of the final coloring operation, giving you performance somewhere between a spiral sewn and a loose wheel. MSRP: Now: $14.94 Out of stock Compare Quick view 32 PLY CUSHION BUFF - 8 Inch These buffs are sewn with two rows to slightly stiffen the buff. This improves the speed of the final coloring operation, giving you performance somewhere between a spiral sewn and a loose wheel. MSRP: Now: $17.24 Choose Options Compare Quick view BRASS WIRE SHANK MOUNTED WHEEL Brass Wire Shank Mounted Wheel 1" Dia x 1/8" Shaft MSRP: Now: $3.78 Add to Cart Compare Quick view CANTON FLANNEL WHEEL - 10" X 1/2" Canton Flannel is very soft, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as... MSRP: Now: $8.79 Choose Options Compare Quick view CANTON FLANNEL WHEEL 14" x 1/2" Canton Flannel is very soft, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as... MSRP: Now: $12.09 Out of stock Compare Quick view CANTON FLANNEL WHEEL 4 X 1/2 Canton Flannel is very soft, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as... MSRP: Now: $3.84 Choose Options Compare Quick view CANTON FLANNEL WHEEL 6 X 1/2 Canton Flannel is very soft, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as... MSRP: Now: $4.94 Choose Options Compare Quick view CANTON FLANNEL WHEEL 8 X 1/2 Canton Flannel is very soft, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as... MSRP: Now: $7.14 Choose Options Compare Quick view CLOTH FINGER BUFF - SOFT A highly agressive wheel for quick cutting and polishing. Ideal for buffing contoured items. Made of tough, long lasting cloth. Use with any cutting compound, or greaseless compound. Very economical to use. Wheels have a metal center with 3/4" hole... MSRP: Now: $11.37 Choose Options Compare Quick view DENIM BUFFING WHEEL - 4" x 1/2" Our newest buffing wheel, the denim buffing wheel, is soft enough for any buffing application that calls for cotton wheels, but, because of the sturdy denim construction, it lasts much, much longer than a cotton buff. The faces of these wheels are... MSRP: Now: $7.69 Choose Options Compare Quick view DENIM BUFFING WHEEL - 6" x 1/2" Our newest buffing wheel, the denim buffing wheel, is soft enough for any buffing application that calls for cotton wheels, but, because of the sturdy denim construction, it lasts much, much longer than a cotton buff. The faces of these wheels are... MSRP: Now: $8.79 Out of stock Compare Quick view DENIM BUFFING WHEEL - 8" x 1/2" Our newest buffing wheel, the denim buffing wheel, is soft enough for any buffing application that calls for cotton wheels, but, because of the sturdy denim construction, it lasts much, much longer than a cotton buff. The faces of these wheels are... MSRP: Now: $12.09 Out of stock Compare Quick view DOMET FLANNEL WHEEL - 4" X 1/2" Domet flannel is very the softest available material, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the... MSRP: Now: $3.84 Choose Options Compare Quick view DOMET FLANNEL WHEEL - 6" X 1/2" Domet flannel is very the softest available material, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the... MSRP: Now: $4.94 Choose Options Compare 1 2 3 4 5 6 Next 1 2 3 4 5 6 Next Compare Selected × OK
