Quick view Caswell sku: GPPL9 GP PLATES 8 x 8 MSRP: Now: $14.84 Add to Cart Compare Quick view Caswell sku: DYEBLK27 BLACK ANODIZING DYE - 4 OZ MSRP: Now: $27.71 Add to Cart Compare Quick view Caswell sku: ALSE22 Anodizing Sealant - 1 lb MSRP: Now: $31.89 Add to Cart Compare Quick view Caswell sku: ALDEOX28 Deoxidizer/Desmut - 1 Quart MSRP: Now: $23.64 Add to Cart Compare Quick view Caswell sku: CWHEEL ANODIZING COLOR WHEEL MSRP: Now: $4.61 Add to Cart Compare Quick view Caswell sku: ATK1 Anodize Touch Up Kit MSRP: Now: $32.99 Add to Cart Compare Quick view Caswell sku: DYEBLK75 BLACK ANODIZING DYE - 1 PINT MSRP: Now: $97.01 Add to Cart Compare Quick view Caswell sku: DYERB9 RED BORDEAUX 2R ANODIZING DYE - 4OZ MSRP: Now: $10.55 Add to Cart Compare Quick view Caswell sku: TW21 2 X 3 FOOT TITANIUM WIRES MSRP: Now: $12.09 Add to Cart Compare Quick view Caswell sku: ANSTP1G ANODIZE & CHROME STRIPPER MSRP: Now: $54.44 Add to Cart Compare Quick view Caswell sku: ANFUM10 ANODIZE FUME SUPPRESSANT MSRP: Now: $14.84 Add to Cart Compare Quick view Caswell sku: ALDG Aluminum Degreaser Powder - 2lb Makes 3 Gallons MSRP: Now: $30.24 Add to Cart Compare Quick view Caswell sku: STRP5 ANODIZE & CHROME STRIPPER - 8 OZ MSRP: Now: $7.69 Add to Cart Compare Quick view Caswell sku: DYEB9 BLUE 4A ANODIZING DYE - 4OZ MSRP: Now: $10.55 Add to Cart Compare Quick view Caswell sku: DYEEB9 ELECTRIC BLUE ANODIZING DYE - 4OZ MSRP: Now: $10.55 Add to Cart Compare Quick view GP PLATES 8 x 8 "General Purpose" plates. Ideal for larger anodizing systems (use as cathodes), or stripping tanks. Lead sheet is 1/32" thick. Can also be used as an anode when chrome plating. MSRP: Now: $14.84 Add to Cart Compare Quick view BLACK ANODIZING DYE - 4 OZ These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye... MSRP: Now: $27.71 Add to Cart Compare Quick view Anodizing Sealant - 1 lb Nickel Acetate based sealer. Use at the rate of 1 oz to 1 gal of water. This 1 lb bag makes 16 gallons. Bath life is 14-60 days, depending on use. Heat to 210 deg F, and seal for 5-30 minutes. MSRP: Now: $31.89 Add to Cart Compare Quick view Deoxidizer/Desmut - 1 Quart 1 Quart mixes with 2 gallons of water. Use to minimize smutting of aluminum parts before anodizing or plating. Use at 70-110 deg F, for 1-3 minutes. Contains Hazardous Goods. Shipping restrictions apply. Ground shipping only to the Continental USA... MSRP: Now: $23.64 Add to Cart Compare Quick view ANODIZING COLOR WHEEL The color wheel helps the anodizer, or painter, to decide which colors to mix to achieve their desired results. MSRP: Now: $4.61 Add to Cart Compare Quick view Anodize Touch Up Kit Anodize Touch Up Kit Repair Scratched or Damaged Black Anodize Kit Contains: 4 oz Anodize Touch Up Liquid 4 oz Cleaning Solution 4 oz Sealing Solution Protective Gloves Cotton Swabs Instructions Our Anodize Touch Up Kit is ideal for... MSRP: Now: $32.99 Add to Cart Compare Quick view BLACK ANODIZING DYE - 1 PINT These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 1 Pint of dye... MSRP: Now: $97.01 Add to Cart Compare Quick view RED BORDEAUX 2R ANODIZING DYE - 4OZ 4oz Dye - Makes 2 Gallons MSRP: Now: $10.55 Add to Cart Compare Quick view 2 X 3 FOOT TITANIUM WIRES 2 x 3 foot long Titanium Wires, for hanging parts into the anodizing tank. MSRP: Now: $12.09 Add to Cart Compare Quick view ANODIZE & CHROME STRIPPER Anodize & Chrome Stripper is a super fast commercial grade stripper. It outperforms all others in speed and quality. Does not attack the aluminum. 1 lb of powder makes 3 gallons. Contains Hazardous Goods. Shipping restrictions apply. Ground... MSRP: Now: $54.44 Add to Cart Compare Quick view ANODIZE FUME SUPPRESSANT Add 4 oz of Fume Suppressant to a 5 gallon anodize bath, to reduce acid fumes. MSRP: Now: $14.84 Add to Cart Compare Quick view Aluminum Degreaser Powder - 2lb Makes 3 Gallons This special degreaser for Aluminum quickly cleans any aluminum alloy without etching. Mix 2 lbs of cleaner with 3 gallons of distilled water in a stainless steel container. Heat to 130 deg F on a hotplate. Immerse aluminum parts for 3-10 minutes prior... MSRP: Now: $30.24 Add to Cart Compare Quick view ANODIZE & CHROME STRIPPER - 8 OZ 8 fl oz of stripping solution. To strip anodize, immerse parts for 5-30 minutes. To strip chrome, use a stainless steel wand and 12V DC. Contains Hazardous Goods. Shipping restrictions apply. Ground shipping only to the Continental USA. Please call +1... MSRP: Now: $7.69 Add to Cart Compare Quick view BLUE 4A ANODIZING DYE - 4OZ These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye... MSRP: Now: $10.55 Add to Cart Compare Quick view ELECTRIC BLUE ANODIZING DYE - 4OZ These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye... MSRP: Now: $10.55 Add to Cart Compare 1 2 3 4 5 6 Next 1 2 3 4 5 6 Next Compare Selected × OK
