|   Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The large bars are 1.25" x 1.25" x 6" and weigh approx. 1.5 lb. each. We believe these industrial size bars represent a better value than the packaged tubes being marketed.  |
SDS
11 Reviews Hide Reviews Show Reviews
Perfect for my needs.
I have a small brass cleaning business in NC and this is what I use everyday. It cuts great and with a little pressure can remove lacquer without chemicals. I love it, and continue to use it everyday.
great service
just what I ordered! prompt delivery
performs as expected
Good first step for smooth aluminum parts.
Good quality & huge size
This is much bigger in reality than I had pictured it. WIll last a long time and get me through multiple projects.
Great
We needed this to polish our 1965 Airstream Trailer. It is working great.
Love it ... even more now
I've always been happy with your buffing compounds. Now I'm happier -- the new cardboard wrapping works great! My bars arrived in perfect condition. Thanks for all you do! I've been a satisfied Caswell customer for several years and have no plans to shop elsewhere. Keep up the fine work!
Great product!
