null
Additional Items Required
Get Our Plating Manual
Anodizing Kits
Caswell Anodizing Systems
VIEW DYES AND COLORS HERE
  • Hardcoat Type III Anodizing System
    Hardcoat Type III aluminum anodizing is a coating frequently found on firearms and aircraft parts. It is a much thicker and harder coating than a standard anodize coating, and is not usually dyed.  Standard dyed Type II anodize is generally around 0.75 -...
    $868.25
    Add to Cart
  • Standard Anodizing Kit Standard Anodizing Kit
    A revolution in Small Scale Anodizing!   Provides a durable anodized surface - which can easily be dyed. Simple to operate - Predictable consistent results Low Current Density means – Inexpensive power source Low Current Density means –...
    $662.85
    Choose Options
  • Titanium & Niobium Anodizing Kit Titanium & Niobium Anodizing Kit
    Titanium, Niobium and Other Reactive Metals Anodizing System Titanium and Niobium can be anodized to create a myriad of colors, rainbow effects and other creative colored patterns simply and easily with our kit. The metal is cleaned with the included...
    $541.41
    Add to Cart
