Quick view Caswell sku: ET1 Electroless Tin Plating Kit - 1 Gallon MSRP: Now: $580.64 Add to Cart Compare Quick view Caswell sku: ET2 Electroless Tin Plating Kit - 3 Gallon MSRP: Now: $694.47 Add to Cart Compare Quick view Caswell sku: ET3 Electroless Tin Plating Kit - 5 Gallon MSRP: Now: $833.62 Add to Cart Compare Quick view Caswell sku: TINAN TIN ANODE .032 x 4 x 8 MSRP: Now: $80.49 Add to Cart Compare Quick view Caswell sku: TINANOD175 TIN ANODE .062x18x18 MSRP: Now: $667.91 Add to Cart Compare Quick view Caswell sku: TPK2 Tin Electroplating Kit - 1.75 Gal MSRP: Now: $242.24 Add to Cart Compare Quick view Caswell sku: TPK4 Tin Electroplating Kit - 5.25 Gal MSRP: Now: $481.95 Add to Cart Compare Quick view Caswell sku: TINACT1P TIN PLATING ACTIVATOR - 1 PINT MSRP: Now: $33.51 Add to Cart Compare Quick view Caswell sku: TINCON2 TIN PLATING CONCENTRATE - Makes 1.75 Gallons MSRP: Now: $58.18 Add to Cart Compare Quick view Caswell sku: TINC1G Tin Plating Concentrate 1 Gal makes 8 Gal MSRP: Now: $181.52 Add to Cart Compare Quick view Caswell sku: CETIN1G TINNING SOLUTION - 1 GALLON MSRP: Now: $530.04 Add to Cart Compare Quick view Electroless Tin Plating Kit - 1 Gallon Electroless Tin Plating Kit Tin Plate Copper, Brass, Gold and Copper Based Alloys Without Power Or Heat! Simple to use. Plates tin over copper, brass, gold and copper based alloys in seconds! No... MSRP: Now: $580.64 Add to Cart Compare Quick view Electroless Tin Plating Kit - 3 Gallon Electroless Tin Plating Kit Tin Plate Copper, Brass, Gold and Copper Based Alloys Without Power Or Heat! Simple to use. Plates tin over copper, brass, gold and copper based alloys in seconds! No... MSRP: Now: $694.47 Add to Cart Compare Quick view Electroless Tin Plating Kit - 5 Gallon Electroless Tin Plating Kit Tin Plate Copper, Brass, Gold and Copper Based Alloys Without Power Or Heat! Simple to use. Plates tin over copper, brass, gold and copper based alloys in seconds! No... MSRP: Now: $833.62 Add to Cart Compare Quick view TIN ANODE .032 x 4 x 8 4" x 8" x 0.032" Thick Tin Anode for Tin Electroplating MSRP: Now: $80.49 Add to Cart Compare Quick view TIN ANODE .062x18x18 Tin Anode 18" x 18" (Large) MSRP: Now: $667.91 Add to Cart Compare Quick view Tin Electroplating Kit - 1.75 Gal Courtesy JP-Tinsmith Ideal for model Tin-ware Trains, antique tin-ware, Cooking Utensils, Electronics, Buss Bars, Tools and much more Tin is a very commonly used metal for the protection of st MSRP: Now: $242.24 Add to Cart Compare Quick view Tin Electroplating Kit - 5.25 Gal Courtesy JP-Tinsmith Ideal for model Tin-ware Trains, antique tin-ware, Cooking Utensils, Electronics, Buss Bars, Tools and much more Tin is a very commonly used metal for the protection of st MSRP: Now: $481.95 Add to Cart Compare Quick view TIN PLATING ACTIVATOR - 1 PINT Add to 6.7oz Tin Plating Concentrate to make 1.75 Gals Tin Plating Solution. (6.7oz Concentrate:1 Pint Activator:2 Qts Battery Acid:3.5 Qts Distilled Water) MSRP: Now: $33.51 Add to Cart Compare Quick view TIN PLATING CONCENTRATE - Makes 1.75 Gallons Makes 1.75 Gallons Tin Electroplating Solution. Mix 6.7oz Concentrate, 1 Pint Activator, 2 Qts Battery Acid and 3.5 Qts Distilled Water MSRP: Now: $58.18 Add to Cart Compare Quick view Tin Plating Concentrate 1 Gal makes 8 Gal Mix 3.5 qts of distilled water and 2 qts of battery acid, then add 1 Quart concentrate and 1 Pint activator. Makes 1.75 gallons. CAUTION: Add acid to water, not water to acid. MSRP: Now: $181.52 Add to Cart Compare Quick view TINNING SOLUTION - 1 GALLON Caswell Tinning Solution Highly recommended when plating over conductive paints. Resolves a mutlitude of problems including patchy plating and eliminates the need for multiple connecting wires to the... MSRP: Now: $530.04 Add to Cart Compare Compare Selected × OK
