Quick view Caswell sku: 3DKIT 3D Printed Parts Plating Kit MSRP: Now: $314.99 Choose Options Compare Quick view sku: ABR1 Airbrush Set MSRP: Now: $55.65 Out of stock Compare Quick view Caswell sku: BSBEX Baby Shoe Bronzing Kit For Export MSRP: Now: $583.15 Add to Cart Compare Quick view Caswell sku: CU1 Bright Acid Copper Plating Kit - 1.5 Gal MSRP: Now: $235.28 Add to Cart Compare Quick view Caswell sku: CU4 Bright Acid Copper Plating Kit - 15 Gal MSRP: Now: $1,374.30 Add to Cart Compare Quick view Caswell sku: CU2 Bright Acid Copper Plating Kit - 3 Gal MSRP: Now: $318.77 Add to Cart Compare Quick view Caswell sku: CU3 Bright Acid Copper Plating Kit - 4.5 Gal MSRP: Now: $430.09 Add to Cart Compare Quick view Caswell sku: CSEAL4 CASWELL SEALER - 4 FL OZ MSRP: Now: $13.90 Add to Cart Compare Quick view Caswell sku: SEAL1G CASWELL SEALER CONCENTRATE - 1 GALLON MSRP: Now: $170.76 Add to Cart Compare Quick view Caswell sku: SEAL45 CASWELL SEALER CONCENTRATE - QT MSRP: Now: $76.52 Add to Cart Compare Quick view Caswell sku: BSB1 Complete Baby Shoe Bronzing Kit MSRP: Now: $944.94 Add to Cart Compare Quick view Caswell sku: CCP1P COPPER CONDUCTIVE PAINT - 1 PINT MSRP: Now: $299.00 Add to Cart Compare Quick view Caswell sku: CCP COPPER CONDUCTIVE PAINT - 4OZ MSRP: Now: $89.00 Add to Cart Compare Quick view Caswell sku: ELCU1 Electroless Copper Kit - 1 Pint MSRP: Now: $163.19 Choose Options Compare Quick view Caswell sku: ELCU2 Electroless Copper Kit - 1 Quart MSRP: Now: $314.99 Choose Options Compare Quick view 3D Printed Parts Plating Kit Plate 3D Printed Parts Easily Plates over PLA, ABS, PVA, Nylon and More Includes Highly Conductive Graphite Bearing Paint Easily Create Professional Looking Metallic Parts At Home Plates A Bright,... MSRP: Now: $314.99 Choose Options Compare Quick view Airbrush Set Specifications: Double Action Trigger for Air-Paint control. Precision machined nozzle and fluid cap, suitable for graphic art work. Nozzle: 0.3mm Required Air Pressure: 15-30 PSI Hose Adapter End:... MSRP: Now: $55.65 Out of stock Compare Quick view Baby Shoe Bronzing Kit For Export Now you can join the thousands of people that are bronzing baby shoes and similar objects, as a hobby or as a business, with our new Baby Shoe Bronzing Kits, and not worry about the shipping expense... MSRP: Now: $583.15 Add to Cart Compare Quick view Bright Acid Copper Plating Kit - 1.5 Gal Bright Acid Copper Plating Kit Our new and improved copper plating system now gives constant bright copper plating, that requires little to no polishing after plating. For the restorer, copper... MSRP: Now: $235.28 Add to Cart Compare Quick view Bright Acid Copper Plating Kit - 15 Gal Bright Acid Copper Plating Kit Our new and improved copper plating system now gives constant bright copper plating, that requires little to no polishing after plating. For the restorer, copper... MSRP: Now: $1,374.30 Add to Cart Compare Quick view Bright Acid Copper Plating Kit - 3 Gal Bright Acid Copper Plating Kit Our new and improved copper plating system now gives constant bright copper plating, that requires little to no polishing after plating. For the restorer, copper... MSRP: Now: $318.77 Add to Cart Compare Quick view Bright Acid Copper Plating Kit - 4.5 Gal Bright Acid Copper Plating Kit Our new and improved copper plating system now gives constant bright copper plating, that requires little to no polishing after plating. For the restorer, copper... MSRP: Now: $430.09 Add to Cart Compare Quick view CASWELL SEALER - 4 FL OZ Caswell Sealer Concentrate Caswell Sealer is a fast drying coating that penetrates porous materials such as cloth, leather, plaster of paris, concrete etc. rendering it non-porous. The... MSRP: Now: $13.90 Add to Cart Compare Quick view CASWELL SEALER CONCENTRATE - 1 GALLON Caswell Sealer Concentrate Caswell Sealer is a fast drying coating that penetrates porous materials such as cloth, leather, plaster of paris, concrete etc. rendering it non-porous. The... MSRP: Now: $170.76 Add to Cart Compare Quick view CASWELL SEALER CONCENTRATE - QT Caswell Sealer Concentrate Caswell Sealer is a fast drying coating that penetrates porous materials such as cloth, leather, plaster of paris, concrete etc. rendering it non-porous. The... MSRP: Now: $76.52 Add to Cart Compare Quick view Complete Baby Shoe Bronzing Kit Now you can join the thousands of people that are bronzing baby shoes and similar objects, as a hobby or as a business, with our new Baby Shoe Bronzing Kits. The kits include 1.5 gallons of plating... MSRP: Now: $944.94 Add to Cart Compare Quick view COPPER CONDUCTIVE PAINT - 1 PINT Copper Conductive Paint Make non-conductive items such as plastics, resins, leather, ceramics, cardboard, flowers, leaves, roses etc. conductive so they can be plated. Copper Conductive Paint is an... MSRP: Now: $299.00 Add to Cart Compare Quick view COPPER CONDUCTIVE PAINT - 4OZ Copper Conductive Paint Make non-conductive items such as plastics, resins, leather, ceramics, cardboard, flowers, leaves, roses etc. conductive so they can be plated. Copper Conductive Paint is an... MSRP: Now: $89.00 Add to Cart Compare Quick view Electroless Copper Kit - 1 Pint Electroless Copper Plating Kit Introducing a new, simple way to make non-metallic parts conductive. Easier to use than conductive paints. The Electroless Copper Plating Kit provides an even,... MSRP: Now: $163.19 Choose Options Compare Quick view Electroless Copper Kit - 1 Quart Electroless Copper Plating Kit Introducing a new, simple way to make non-metallic parts conductive. Easier to use than conductive paints. The Electroless Copper Plating Kit provides an even,... MSRP: Now: $314.99 Choose Options Compare 1 2 3 Next 1 2 3 Next Compare Selected × OK
