Quick view Caswell sku: PH10 10.0 PH BUFFER SOLUTION MSRP: Now: $7.58 Add to Cart Compare Quick view Caswell sku: PH4 4.0 PH BUFFER SOLUTION MSRP: Now: $7.58 Add to Cart Compare Quick view Caswell sku: PH7 7.0 PH BUFFER SOLUTION MSRP: Now: $7.58 Add to Cart Compare Quick view sku: ABR1 Airbrush Set MSRP: Now: $55.65 Out of stock Compare Quick view Sterling Systems sku: BP44 Barrel Plater - 4" x 4" MSRP: Now: $1,953.85 Choose Options Compare SALE Quick view Caswell sku: CWAL Casweld™ AL Aluminum Brazing Rod Kit MSRP: $56.93 Was: $56.93 Now: $44.00 Out of stock Compare Quick view Caswell sku: CWFX1 Casweld™ PM Flux - 2 fl oz MSRP: Now: $18.98 Add to Cart Compare SALE Quick view Caswell sku: CWPM Casweld™ PM Soldering Rod Kit MSRP: $56.93 Was: $56.93 Now: $44.00 Out of stock Compare Quick view Caswell sku: CWFX2 Casweld™ AL Flux - 2 ounces MSRP: Now: $18.98 Add to Cart Compare Quick view Caswell sku: CWS1 Casweld™ Silver Solder Rod - 3/64 x 1 Rod MSRP: Now: $44.28 Out of stock Compare Quick view Caswell sku: CWS2 Casweld™ Silver Solder Rods - 1/16 x 2 Rods MSRP: Now: $125.24 Add to Cart Compare Quick view Caswell sku: ENTHERM ELECTROLESS KIT THERMOMETER MSRP: Now: $27.82 Add to Cart Compare Quick view Caswell sku: PH39 ELECTRONIC PH TESTER MSRP: Now: $64.50 Add to Cart Compare Quick view Caswell sku: FPUMP FILTER PUMP/AGITATOR MSRP: Now: $25.29 Add to Cart Compare Quick view Caswell sku: GT00500 GREEN MASKING 1/2" DOTS - 2000 PER ROLL MSRP: Now: $41.73 Add to Cart Compare Quick view 10.0 PH BUFFER SOLUTION DIGITAL PH TESTER FOR PLATING SOLUTIONS Accurately measures pH ranging from 0-14 pH. Pocket-sized, lightweight instrument will quickly test all your plating solutions, and even your swimming pool... MSRP: Now: $7.58 Add to Cart Compare Quick view 4.0 PH BUFFER SOLUTION DIGITAL PH TESTER FOR PLATING SOLUTIONS Accurately measures pH ranging from 0-14 pH. Pocket-sized, lightweight instrument will quickly test all your plating solutions, and even your swimming pool... MSRP: Now: $7.58 Add to Cart Compare Quick view 7.0 PH BUFFER SOLUTION DIGITAL PH TESTER FOR PLATING SOLUTIONS Accurately measures pH ranging from 0-14 pH. Pocket-sized, lightweight instrument will quickly test all your plating solutions, and even your swimming pool... MSRP: Now: $7.58 Add to Cart Compare Quick view Airbrush Set Specifications: Double Action Trigger for Air-Paint control. Precision machined nozzle and fluid cap, suitable for graphic art work. Nozzle: 0.3mm Required Air Pressure: 15-30 PSI Hose Adapter End:... MSRP: Now: $55.65 Out of stock Compare Quick view Barrel Plater - 4" x 4" These miniature barrel platers are perfect for plating batches of small parts in any of our plating kits. We recommend our 4.5 Gallon size kits for barrel plating use. Simply add your parts, submerge... MSRP: Now: $1,953.85 Choose Options Compare SALE Quick view Casweld™ AL Aluminum Brazing Rod Kit Casweld™ AL Aluminum Brazing Rod Designed for joining all brazable grades of aluminum sheet, plate, tubi MSRP: $56.93 Was: $56.93 Now: $44.00 Out of stock Compare Quick view Casweld™ PM Flux - 2 fl oz 1 x 2 Fluid Ounce Bottle of Casweld™ PM Flux For Casweld™ PM Solder Rods MSRP: Now: $18.98 Add to Cart Compare SALE Quick view Casweld™ PM Soldering Rod Kit Casweld™ PM Soldering Rod 350°F Melting Rods For Pot Metal and Thin Aluminum MSRP: $56.93 Was: $56.93 Now: $44.00 Out of stock Compare Quick view Casweld™ AL Flux - 2 ounces 1 x 2 ounce bottle of Casweld™ AL Flux for use with Casweld™ AL Aluminum Brazing Rods MSRP: Now: $18.98 Add to Cart Compare Quick view Casweld™ Silver Solder Rod - 3/64 x 1 Rod Casweld™ Silver Solder Rod Download our Casweld™ MSRP: Now: $44.28 Out of stock Compare Quick view Casweld™ Silver Solder Rods - 1/16 x 2 Rods Casweld™ Silver Solder Rods Download our Casweld™ MSRP: Now: $125.24 Add to Cart Compare Quick view ELECTROLESS KIT THERMOMETER Glass thermometer for plating or anodizing. Reads 100 deg F - 400 deg F. Ideal for electroless plating and anodizing dye baths, where temperature is critical. MSRP: Now: $27.82 Add to Cart Compare Quick view ELECTRONIC PH TESTER DIGITAL PH TESTER FOR PLATING SOLUTIONS Accurately measures pH ranging from 0-14 pH. Pocket-sized, lightweight instrument will quickly test all your plating solutions, and even your swimming pool... MSRP: Now: $64.50 Add to Cart Compare Quick view FILTER PUMP/AGITATOR Provides constant agitation to plating baths. MSRP: Now: $25.29 Add to Cart Compare Quick view GREEN MASKING 1/2" DOTS - 2000 PER ROLL 2 mil thick, 1/2" Diameter Polyester Dots Ideal for masking screw holes etc. Perfect for Powder coating, anodizing, plating, painting Withstands Up to 400°F MSRP: Now: $41.73 Add to Cart Compare 1 2 Next 1 2 Next Compare Selected × OK
