null
Metal Antiquing
Use these products to antique or change the color of most metals, without power or heat in most cases. Just dip.
To get help choosing a solution, visit our Metal Finishing Solutions Page.
  • ALUMINUM BLACKENER A385
    Aluminum Blackener A385 Ideal For Touching Up Black Anodized Parts Vary the color from a rich pewter gray to a deep black by changing dilution and immersion times. Completely colorfast through age or sunlight. Very stable under a lacquered finish...
    $31.61
    Add to Cart
  • Black Oxide Concentrate - 1 Gallon
    Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 gallon of concentrate makes 10 gallons of blackening solution...
    $261.04
    Add to Cart
  • BLACK OXIDE CONCENTRATE 1 PINT
    Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 pint of concentrate makes 1.25 gallons of blackening solution...
    $42.54
    Add to Cart
  • BLACK OXIDE CONCENTRATE 1 QT
    Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 quart of concentrate makes 2.5 gallons of blackening solution...
    $70.14
    Add to Cart
  • Black Oxide Gel Kit
    Black Oxide Gel Kit
    Easily spot blacken steel (not stainless) or iron. Simply apply the black oxide gel where you want the blackening to occur. The gel keeps the blackener in place. Leave it on the part for 1-3 minutes and rinse off. Seal with Caswell Sealer for a dry...
    $31.61
    Add to Cart
  • Black Oxide Kit - 1.25 Gal Black Oxide Kit - 1.25 Gal
    Blacken Steel Or Iron Parts At Room Temperature This new technique was developed by the commercial gun blue manufacturers as a more environmentally friendly system than the commonly used hot application. Parts requiring blackening are simply placed in...
    $102.34
    Choose Options
  • Black Oxide Kit - 2.5 Gal Black Oxide Kit - 2.5 Gal
    Blacken Steel & Iron Parts At Room Temperature This new technique was developed by the commercial gun blue manufacturers as a more environmentally friendly system than the commonly used hot application. Parts requiring blackening are simply placed in...
    $188.59
    Choose Options
  • Black Oxide Kit - 5 Gal
    $278.29
    Choose Options
  • CASWELL SEALER - 4 FL OZ
    Caswell Sealer Concentrate Caswell Sealer is a fast drying coating that penetrates porous materials such as cloth, leather, plaster of paris, concrete etc. rendering it non-porous. The concentrate can be used as is, or thinned with an equal...
    $13.90
    Add to Cart
  • CASWELL SEALER CONCENTRATE - 1 GALLON
    $170.76
    Add to Cart
  • CASWELL SEALER CONCENTRATE - QT
    $76.52
    Add to Cart
  • PENETRATING SEALER - 1 GAL
    Caswell Penetrating Sealer is used after applying a black oxide coating onto steel or iron parts. It imparts a slightly oily feel to the parts, which displaces moisture and prevents rust. After sealing, dip or brush the parts with the sealer and allow...
    $93.61
    Add to Cart
  • PENETRATING SEALER 1 PINT
    $18.96
    Add to Cart
  • PENETRATING SEALER 1QT
    $25.29
    Add to Cart
  • STAINLESS STEEL BLACKENER 370  - 16OZ STAINLESS STEEL BLACKENER 370  - 16OZ
    Stainless Steel Blackener 370 is an acidic liquid concentrate used full strength or diluted with up to 3 parts water to blacken stainless steel at room temperature. Recommended for color coding parts and blackening engravings on stainless steels...
    $50.59
    Add to Cart
