STAINLESS STEEL BLACKENER 370 - 16OZ
Stainless Steel Blackener 370 is an acidic liquid concentrate used full strength or diluted with up to 3 parts water to blacken stainless steel at room temperature. Recommended for color coding parts and blackening engravings on stainless steels. Produces a pleasing dark gray/black finish. Seal with Caswell Sealer.Contains Hazardous Goods. Shipping restrictions apply. Ground shipping only to the Continental USA. Please call +1 315 946 1213 or contact us for rates to other locations.
Hazardous Shipping Info
GHS Info
SDS
12 Reviews Hide Reviews Show Reviews
Great product, exactly what i needed to blacken stainless parts
I had a bunch of stainless m1 parts that had all the finish worn off. After cleaning the parts and sandblasting i wiped the blackener on and the parts turned black. It was exactly what i was looking for!
Blackened a M1 Garand gas cylinder perfectly, nice consistent color
Great product
Great product. Very easy to use. Great value on the big bottle. Fast shipping.
Worked as expected - easy to use
So far have just tested to see how this worked and attempted some touch-up on a previously finished item. Very good match was achieved in the touch-up work. Blacked stainless barrel material quite well. finish seemed durable.
Unexpectedly Great Results
I refinished a stainless steel putter head, using minimal preparation. Cleaned the head with acetone, scrubbed it with fantastic, and then scrubbed it with distilled white vinegar (my own system obviously). Rinsed it and then dipped it in the blackener and scrubbed the head with 3M great and 3M white abrasive pads while it was submerged in the blackener, Pulled it out, rinsed, and let dry. That was it,. Amazing results for just a little work. Not perfect (not the products fault) but I will do it again and again, and try to improve my technique each time. Fun and rewarding.. A fantastic product!
Great Product...
Very easy to work with and leaves a nice color.
worked as advertized
good product and worked well. would order again.
Needed for golf club
Very good product
Works Great!
I recommend buying a pint of this for applications that require broad coverage.
