ALUMINUM BLACKENER A385
Aluminum Blackener A385
Ideal For Touching Up Black Anodized Parts
Vary the color from a rich pewter gray to a deep black by changing dilution and immersion times. Completely colorfast through age or sunlight. Very stable under a lacquered finish.
Perfect for blacking aluminum castings that cannot be anodized.
Does not dimensionally change the finished part.
An immersion or swab-on finish at room temperature for aluminum surfaces. Mild acidic liquid concentrate used full strength for swab-on finishing and touchup finishing or diluted with 4 parts water for immersion finishing. Frequently used to produce an imitation pewter finish on aluminum surfaces.
Hazardous Shipping Info
GHS Info
SDS
excellent
I use straight to cover any scratches and blacken parts this product works great and this is the second time I bought this product and will buy more makes the scratches disappear and blends in great need it darker leave it on longer so simple
did what it said it would
good delivery time, good cost
