CASWELL SEALER - 4 FL OZ
Caswell Sealer Concentrate
Caswell Sealer is a fast drying coating that penetrates porous materials such as cloth, leather, plaster of paris, concrete etc. rendering it non-porous.
The concentrate can be used as is, or thinned with an equal amount of water. The part is then totally immersed in the solution for 15-30 minutes, then allowed to drip dry. A second application several hours later renders the surface completely smooth and non-porous.
To make the part conductive the part is then sprayed with Copper Conductive Paint or SilvaSpray. Finally, the part can be plated with bright acid copper.
Ideal for plating baby shoes, bone, plants, cloth and other porous items.
Caswell Sealer is also highly effective as a corrosion resistant coating over most metals, including Black Oxide coatings, Silver Plate, Gold Plate, Copy Chrome and antiqued copper or brass. Thickness: 0.09mm.
SDS
6 Reviews Hide Reviews Show Reviews
Caswell Sealer
Great product and easy to use. Used this sealer after black oxide finish on golf iron heads. I liked the matte black finish as opposed to gloss or satin finish of other sealers. As good or better than mi era oil. Quickly absorbs and dries. Use two coats or dips and you are good to go. Highly recommend Caswell products. They are so easy to use and are great quality. Only brand I use for my projects when stripping or plating.
Great!
Great product, I brushed it on to my gold covered guitar pickups, looks like it's going to protect it for the years ahead!
Good stuff
Gives a really nice looking sheen to blackened stainless steel.
Excellent
Easy to use product. Can be dipped or brushed. Dipping worked best for me based on my product.
Needed a sealer
Worked very well
Good product
Works as described easy application and drying time minimal.
