PENETRATING SEALER 1QT
Caswell Penetrating Sealer is used after applying a black oxide coating onto steel or iron parts. It imparts a slightly oily feel to the parts, which displaces moisture and prevents rust.
After sealing, dip or brush the parts with the sealer and allow to contact the part for 1-5 minutes. After sealing, shake off excess and allow to dry.
Hazardous Shipping Info
GHS Info
SDS
Great
Works better than the other sealers I've used
Great product
Follow the directions!
