CASWELL SEALER CONCENTRATE - 1 GALLON
Caswell Sealer Concentrate
Caswell Sealer is a fast drying coating that penetrates porous materials such as cloth, leather, plaster of paris, concrete etc. rendering it non-porous.
The concentrate can be used as is, or thinned with an equal amount of water. The part is then totally immersed in the solution for 15-30 minutes, then allowed to drip dry. A second application several hours later renders the surface completely smooth and non-porous.
To make the part conductive the part is then sprayed with Copper Conductive Paint or SilvaSpray. Finally, the part can be plated with bright acid copper.
Ideal for plating baby shoes, bone, plants, cloth and other porous items.
Caswell Sealer is also highly effective as a corrosion resistant coating over most metals, including Black Oxide coatings, Silver Plate, Gold Plate, Copy Chrome and antiqued copper or brass. Thickness: 0.09mm.
SDS
Excellent sealer
First time using this sealer but I like the way it doesn't leave the oily film on the parts. The finish is a little glossier than the other sealer but fine for automotive restoration. Great product.
