BLACK OXIDE CONCENTRATE 1 QT
Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer.
Mix 1 part Concentrate with 9 parts distilled water. 1 quart of concentrate makes 2.5 gallons of blackening solution. Parts Coverage - 600 to 1200 sq. ft. of surface area blackened per gallon of concentrate.
Immerse the part in the mixed Black Oxide Solution and swirl around for between 30 seconds and 5 minutes. Alternatively, the part may simply be placed in the solution for 5 - 10 minutes. Remove the part from the solution and rinse in fresh water. Use at room temperature.
Hazardous Shipping Info
GHS Info
SDS
23 Reviews Hide Reviews Show Reviews
Works really well. some tips and tricks
make sure you de-grease really well. Use Castrol de-greaser from Walmart (9/gal) and it works great full strength. Rinse in distilled H2O only. no tap water. Warm solution to 120 deg. F. it really helps. Remove and rise in distilled water. Coat with penetrating fluid for a more genuine look but is not the longest lasting solution. The Caswell sealer works really well and lasts long than oil. They say to dip in sealer immediately but i have rinsed with distilled H2O. Dried and used sealer with great results. Best of luck. This stuff works great.
The Best For Less
I'm a gunsmith and I use this a lots its a great product and will keep using it if the keep selling it and it is very easy to use and safe on the environment just make sure its clean.
Great Product Great Price
I'm a gunsmith and I used this on a couple of old and new guns that I was working on for customers and me and the customer was very very pleased, easy to use just be sure you get it clean and its very easy on the environment.
Only way to blacken automotive fasteners.
I have used this blackening solutition before and it works great. Just sandblast the part and put it in the solution then seal it.
Excellent Service
Very good product, leaves great finish
Excellent Service
Black Oxide Concentrate
Great product, and a great company to deal with. Will order from them again. Thanks
Good product slow service
Good product, slow service.
Works well and lasts a long time
I use this in a home based production environment to put a protective coating on the small brackets and parts I make for an Indy type race car.
