Black Oxide Concentrate - 1 Gallon
Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer.
Mix 1 part Concentrate with 9 parts distilled water. 1 gallon of concentrate makes 10 gallons of blackening solution. Parts Coverage - 600 to 1200 sq. ft. of surface area blackened per gallon of concentrate.
Immerse the part in the mixed Black Oxide Solution and swirl around for between 30 seconds and 5 minutes. Alternatively, the part may simply be placed in the solution for 5 - 10 minutes. Remove the part from the solution and rinse in fresh water. Use at room temperature.
Hazardous Shipping Info
GHS Info
SDS
Website ordering is fabulous
I have ordered items via website and it is very easy to use. I also like the notifications that are received when placing the order and when product has shipped.
