PENETRATING SEALER 1 PINT
Caswell Penetrating Sealer is used after applying a black oxide coating onto steel or iron parts. It imparts a slightly oily feel to the parts, which displaces moisture and prevents rust.
After sealing, dip or brush the parts with the sealer and allow to contact the part for 1-5 minutes. After sealing, shake off excess and allow to dry.
Hazardous Shipping Info
GHS Info
SDS
Good Sealer, Dries in a Day or Two
I refinished some raw Mizuno wedges with the black oxide system. Then I ust brushed on the sealer and let it dry overnight. Projvides a nice matte finish over the black oxide. Does not prevent rust altogether but provides enough protection that you can just rub down the club heads and they look near-to-perfect.
Excellent penetrating capability.
First time user: Great penetrating, but leaves somewhat blotchy finish that can be readily wiped to a uniform appearance. Protection ability yet unknow.
