BLACK OXIDE CONCENTRATE 1 PINT
Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer.
Mix 1 part Concentrate with 9 parts distilled water. 1 pint of concentrate makes 1.25 gallons of blackening solution. Parts Coverage - 600 to 1200 sq. ft. of surface area blackened per gallon of concentrate.
Immerse the part in the mixed Black Oxide Solution and swirl around for between 30 seconds and 5 minutes. Alternatively, the part may simply be placed in the solution for 5 - 10 minutes. Remove the part from the solution and rinse in fresh water. Use at room temperature.
Hazardous Shipping Info
GHS Info
SDS
12 Reviews Hide Reviews Show Reviews
Black oxide concentrate
Works exactly as advertised, taking my restoration to a whole new level!! Thanks Caswell!!
Wow!
So easy and fast. This stuff is by far the best. Everything came out great and looks like factory! U can’t go wrong.
Blacking or Bluing
As a machinist, I need to add rust protection to nearly everything I make, like tool holders. I first tried Mark Lee's Bluing but was sadly disappointed in the blochy gray finish so I wire brushed it all off and redid everything in Caswell's Blacking. Wow, what a difference. The Blacking in uniform and much darker. I use Vaseline to finish the surface; it works much better than White grease.
Custom knife
I have been using this for about 4 years to get a great pakerized look on my knifes. I bead blast the blade and put it directly into the solution for 2 to 10 min. And it comes out looking great. Much better then powder coat. Poppa D’s Workshop
Easy to Use, With Great Results
Followed instructions and finish is all I hoped for. Refinished some raw Mizuno Wedges. Prep was not too extreme and results were fantastic. A great product!
Black Oxide Concentrate/Black Oxide Kit
This product does exactly what it claims to do....Results are immediate....Depending on desired degree of blackness the user can manipulate/adjust exposure time to gain better result.s....It even works on hardened steel. Great product!
Excellent product at an excellent price!!!
I'm in the custom pellet-gun business and use this product to blue all of the steel custom parts I make or re-blue. It's a very forgiving and easy to use. Just make sure the steel is clean, saturate the part or soak it for a few minutes, wash it off with soapy water and oil it. Done, it's that simple, love it!
Works Great!
Clean well and dip for a great black finish.
Outstanding touch-up product.
Only used as touch-up for black oxide fisish. Performance superior to Brownells "T -4 Touch-up" at half the cost.
