Caswell Penetrating Sealer is used after applying a black oxide coating onto steel or iron parts. It imparts a slightly oily feel to the parts, which displaces moisture and prevents rust.
After sealing, dip or brush the parts with the sealer and allow to contact the part for 1-5 minutes. After sealing, shake off excess and allow to dry.
                Recommended Skill Level
                    Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
  			 GHS Info
			 SDS
                Excellent ServiceDoes very good job.
