EXTRA LONG SHAFT EXTENDER RH 5/8"
Designed especially for larger buffing & polishing units.
The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces.
Slides onto 5/8" diameter shaft and tightens with two grub screws.
Great for mounting larger sized wheels. 6-1/2" Long. Threaded section is 2" long. Fits 1/2" Wheel Holes
Works well
They do what I need them to do so I have no complaints. They are black when you get them though.
fast shipping with good products
I get all my polishing needs from caswell plating for some time. Their products has never let me down. shipping is always fast. If you want simplicity with good products this is where it's at.
