| Attach these mandrels to an electric motor with a V Belt to make a HIGH QUALITY, low cost work station for various sanding, polishing and buffing operations. Will run wheels up to 1" thick. Features high quality precision grade die cast ball bearing pillow blocks, permanently sealed and lubricated. Threaded shaft ends L/H & R/H 2" diam V pulley (for 1/2 belts) & hex nuts with flanged washers for shaft ends. |
Well constructed
Set screws for collars need a bit of locktite to keep them secure, but otherwise a nice item.
