Flapper Adapter Metric M12 x 1.75
The Flapper Adapter mounts onto any angle grinder with a metric M12 x 1.75 shaft, and allows you to mount any wheel with a 1/4" shaft onto your angle grinder. Mount flap wheels, cutoff wheels, buffing wheels, grinding wheels, carbide burrs etc.
Made in the USA. 303 Stainless body with Tool Steel Collets, 1/4" Collet, and Nut.
