EXTRA LONG SHAFT EXTENDER 1/2 RH
Designed especially for larger buffing & polishing units.
The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces.
Slides onto 1/2" diameter shaft and tightens with two grub screws.
Great for mounting larger sized wheels. 6-1/2" Long. Threaded section is 2" long. Fits 1/2" Wheel Holes
3 Reviews Hide Reviews Show Reviews
Nice extender
Well built and affordable. I do sometimes end up with a wobble but I attribute that to my grinder
Great Product as always
should have bought long time ago...added working area
These work perfectly!!!
These worked perfectly to adapt more wheels and create a wider buffing surface. They also helped move the wheels further away from the motor - very important when buffing lacquer on a hand-made guitar!!!
