For use with the NotcHead Polishing Grip, this larger collet makes a valuable tool even more versatile. The soft aluminum jaws quickly grip the threads of the bolt so the head can be polished 360 without damage. It secures the bolt evenly with a four-jaw chuck, preventing it from catching on the wheel and taking flight or burning your hands. Easily fits into the same handle as NotcHead Polishing Grip and grips bolt sizes from 7/16" up to 1/2". CNC machined out of aluminum, then hard anodized for extra durability Limited Lifetime Warranty Made in the USA Weight: 4.7 oz (~ 0.3 lbs) Length: 3 1/4" Width: 1 3/4"
